I have a CP7 display that i have connected to a Fez Hydra. As long as i press the screen (a button), i need to increment a counter on the screen. To make the counter a bit slower, i have used a 200 millisecond sleep. My problem is the UI is not showing the updated value until released event. If i do it in a separate thread, i get the verify access problem.
The same works perfectly fine with a T35 display where i use Timer (tickevent handler).
a small program which shows this problem would help to get an answer.
//Main function
display_CP7.ScreenPressed += new Display_CP7.TouchEventHandler(display_CP7_ScreenPressed);
display_CP7.screenReleased += new Display_CP7.TouchEventHandlerTouchReleased(display_CP7_screenReleased);
//Inside Screen Pressed
//Removing the touch event so that the timer event is not fired again. the touch event will be put back in Screen Released event
display_CP7.ScreenPressed -= new Display_CP7.TouchEventHandler(display_CP7_ScreenPressed);
stickyTimer = new GT.Timer(stickyDelay);
stickyTimer.Tick += new GT.Timer.TickEventHandler(timerPowerPlus_Tick);
stickyTimer.Start();
//Inside timerPowerPlus_Tick
powerLabel.TextContent = "0.5 W";
//As long as the key is pressed, the tick will increment the powerLabel text.
//Screen Released event code
is_Released = true;
if (stickyTimer != null)
stickyTimer.Stop();
stickyTimer = null;
you have provided code snippets, not a complete program, so I am unable to completely understand what you are trying to do, or run the. program on my machine.
because your code is incomplete, I do not know GUI library you are using.
I suggest you simple program without the GUI and write the counter using debug.print.
I suggest you do not dynamically subscribe and unsubscribe to events.
