Hi, I am new to .NET Gadgeteer platform. After I followed the instructions in https://www.ghielectronics.com/support/.net-micro-framework and wrote a dummy program, I tried to connect the .NET Gadgeteer modules to the computer, but I got the error as shown in the picture. I repaired the USB driver (X64), but the error remains.
The modules consist of FEC Spider 1.0 mainboard, USB Client DP, WIFI-RS21 and a light sensor.
@ Aron - And I have also tried to update the driver automatically and manually selecting from .\GHI Electronics\GHI Premium NETMF v4.2 SDK\USB Drivers. It did not work.
@ Aron - I am using GHI USB Client DP to support the power of mainboard FEZ Spider 1.0. And I do have VMware Workstation installed on the laptop. But when I connected the modules, no VM was running.
Until you can get the driver installed and the device successfully recognized, you can’t proceed to deploy code to the device - so we need to get that working. Can you show us a picture of Device Manager and expand out the details on the unknown device? I would also try to put the device in loader mode (see the card that came with your Spider on setting the switches) and see what appears in Device Manager.
And once we get past this, you should make sure you update the firmware !
