The library read only raw data but this morning I became developer for NDEF project http://ndef.codeplex.com because I will port it on .Net Micro Framework.
In this way you can parse raw data for enconding NDEF format.
I just had a conversation this morning with someone regarding Bluetooth vs NFC for my project (I really want to do both) but that I really wasn’t qualified to write a driver for an NFC NETMF project.
Then BAM!
I find yours.
I ordered the same parts you talked about in your post, but would it be right to believe that this will talk to any board with a NXP PN532 chip in it?
Hi willy,
I’m happy that my work could be useful for you !
Regarding the board, the driver is for NXP PN532 chip so you can use any breakout board with this chip not only the board I used for testing.
Tipically these boards are useful to avoid to make a PCB yourself or soldering component; with the board you have all the pin of the chip available with simple connections.
