Just wondering if there is a way to see the “CPU” utilization or “Memory Utilization”.
When i try to use the ENC28 ethernet module with the Hydra it starts to respond really slowly on buttons events.
I’ve many stuff attached to the board ok… two buttons, 2 RGB led, a character display, 3 DS1820B thermometer captured every 30 seconds, a custom module with 4 digital input (just a classic pull down resistor + a timer that reads this values every 15 seconds) and 4 out put ports that are commanded by some IF codes depending on the themperatures…
I’m pushing too much??
As power i’ve a dual power with 12V 3 A power supply
I’m even wondering if i’m driving bad the DS1820B (i’ve a 1K resistor since the cabling is 3 meter long)
