Hi All,
I have just purchased two Boards from GHI, FEZ Duino and FEZ Pico.
I have followed instructions on Getting Started and installed MS VS 2022 community on my PC and installed the TinyCLR OS Project Extension.
I have tested a code that I copied from GHI site to test the FEZ Pico and Blink the onboard LED on PA8 and I was NOT able to make it blink, I got an Error that I have not had the correct version installed for the board at hand.
I downloaded the TinyCLR Config and connected to my FEZ Pico and saw that the Firmware is OLD 2.1.0.6100
, and I wanted to update it tom latest 2.2.0.5100
- But with no luck.
I was able to connect the board and see the green message say “connected” but…every version I tried to upgrade it to - I was getting an Error that the board is not connected and I have connected it back and tried again and with the same error again.
I even tried 2.1.0.6200
and with no luck at all.
I would like to upgrade the FEZ Pico to the latest that I will be able to program it from MS VS 2022 and intended.
I did managed to reinstall the Extension for VS in version 2.1 to meet the FW on the board and was able to program it - But I do want to upgrade the FW version that I will have the ability to program more boards in the IDE that uses Most recent FW and also the latest.
Please assist with upgrading the FW for my FEZ Pico that it will be running on 2.2.0.5100
Arye
