I have installed the QFE2 and the new software from GHI’s site.
however in the end of the installation when i am selecting the option to update my spider. I am getting a message saying cant connect to mainboard follow manual steps at
I tried to follow the steps given on the above link but after i select all the hex files i get this error message (See pic).
Please advice me how to proceed.
Note. when i tried the hex files from the 4.1 version folder i did not get and error and I was able to successfully upload the firmware, but the 4.2 is giving me trouble.
When you did manual steps, you did enter GHI loader, use E to erase all, loaded tinybooter from 4.2 folder and then trying to load firmware from 4.2 folder?
Gus I changed laptop and downloaded the teraterm again. I was able to follow the steps to upload the “TinyBooter.GHI” using the File > Transfer > XMODEM > Send…
After that. when i check it in mf deploy i cannot see my device…
there is nothing when i select the usb option.
ok good. You can select your device (will be EMX_EMX) from configuration in your project or use the updater this time, which will change the device name to “gadgeteer”.
I recommend you use the “spider updater” and make sure you run the updater from NETMF 4.2 not 4.1 C:\Program Files (x86)\GHI Electronics\GHI Premium NETMF v4.2 SDK\Firmware Update
