I am trying to toggle IO33 and IO31 but the IO level is low all the time even when I Write(true).
_cs = new OutputPort(chipSelectPin, true);
_cs.Write(true)
The pins are for I2C, could this be the problem?
_cs.Write(true)
They are open drain. You need pull ups
Thanks! that did the trick
