I’m working on a SCM20260 development board with 2.1.0-preview4 firmware to better understand the power management functionality. I have an external pushbutton switch with pullup connected to PA0 (WKUP pin).
Functionally, my goal is to be able to:
- Put the SCM20260 into Sleep state.
- At switch press, wake from Sleep and do some work.
- Shutdown the SCM20260.
- At switch press, reset the SCM20260.
In my setup, I can put the SCM20260 to Sleep, wake upon switch press, and perform some work in the event handler. However, I receive a System.InvalidOperationException when I call Shutdown() and the processor remains active.
Below is an example which I’ve tried running. Is there anything that needs to be setup or handled differently to get the SCM20260 to shutdown?
static void Main()
var LED = GpioController.GetDefault().OpenPin(SC20260.GpioPin.PB0);
LED.SetDriveMode(GpioPinDriveMode.Output);
// --- Test Sleep ---
var wakePin = GpioController.GetDefault().OpenPin(SC20260.GpioPin.PA0);
wakePin.SetDriveMode(GpioPinDriveMode.InputPullUp);
wakePin.ValueChangedEdge = GpioPinEdge.FallingEdge;
wakePin.ValueChanged += WakePin_ValueChanged;
Debug.WriteLine("Doing some work before I sleep...");
for (int i = 0; i < 3; i++)
LED.Write(GpioPinValue.High);
Thread.Sleep(250);
LED.Write(GpioPinValue.Low);
Thread.Sleep(250);
Power.Sleep(); // External switch with pullup awakens.
Debug.WriteLine("Doing some work after I wake...");
Thread.Sleep(250);
Thread.Sleep(250);
// --- Test Shutdown ---
try
// Throws 'System.InvalidOperationException' in GHIElectronics.TinyCLR.Native.dll
// for each of the following.
//Power.Shutdown(true, DateTime.MaxValue);
//Power.Shutdown(true, DateTime.Now.AddSeconds(5));
Power.Shutdown(false, DateTime.Now.AddSeconds(5));
catch { }
Debug.WriteLine("If I get here, the SCM20600 did not shutdown!");
private static void WakePin_ValueChanged(GpioPin sender, GpioPinValueChangedEventArgs e)
Debug.WriteLine("Wakeup Pin Interrupt!");
