Hello,
I’ve a project that did work well for months. Starting from yesterday, every time I run debug using F5 the debugger doesn’t attach anything. After a lot of time, it exits, or worse I may stop them. The breakpoint on the first code line is never reached or executed. If I try to pause it, it responds that the debugger is still trying to attach the process.
If I open ad other program and run it, everything works, so the Panda is ok and my environment too.
Tried to remove and re-add, still nothing.
Firmware is not changed, the project did work until yesterday And the second project, really similar to first, is debugging well…
Are you running both projects on the same Hydra? It sounds like you have a tight loop in ProgramStarted. Make sure you have no loops there. You should be using GT.Timer to offload any code that does anything more than initialization. If these are actually different Hydra’s. Then erase the firmware on the problem one and re-apply so that the blocking program is removed.
Have you made any changes to the program since the last time you ran it? If you have try to return the program to the original state that it worked in and see if that will help. I do not remember what it was or which board/system I worked on but I had the issue where a certain line of code somehow prevented the debugger from working or deploying but I would not get any errors.
