Hopefully someone reading this uses or has used uIP before, I am running into an issue where I have 2 non pc based ethernet connection sending TCP packets back and forth.
The issue, if I set connection A to only send out 256 bytes of data per packet everything works fine…But if I increase the packets sent from connection A to connection B it will send a few packets and just stop and then the connections will just keep sending alive packets to one another. I tried adjusting the receive buffer size on connection B but it doesnt seem to have any affect.
Thanks in advance for any help.
