UDP still broken
Hello guys,
I’m still not having success with UDP Broadcast while using the latest SDK 4.2.9.0:
try creating a UPD program that would join a Multicast Group and Monitor Port 1900. this worked fine in 4.1
thank you.
UDP problem was in our drivers and that is fixed. If there are problems handling multicast then that would be on the TCP/IP stack level, which may also need Microsoft involvement. We are looking into this as someone else already pointed this out.
Of course, any details/code you can provide to help us solve this is appreciated.
