UDP socket.RemoteEndPoint
I am trying to catch some broadcast packets from some other devices on the network. When I try to get the socket.RemoteEndPoint so I can get the IP address of the device that sent the broadcast I get and error. If I remove that line it continues on as it should and the data from the device is readable.
What am I doing wrong?
Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (8)
Message:
GHIElectronics.TinyCLR.Devices.Network.Provider.NetworkControllerApiWrapper::GetRemoteAddress [IP: 0000]
System.Net.Sockets.Socket::GetEndPoint [IP: 003d]
System.Net.Sockets.Socket::get_RemoteEndPoint [IP: 0005]
    int port = 5556;
    var ipEndPoint = new IPEndPoint(IPAddress.Any, port);
    var socket = new Socket(System.Net.Sockets.AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
    byte[] data = new byte[1024];
    string name;
    try
        socket.Bind(ipEndPoint);
            while(!socket.Poll(10,SelectMode.SelectRead))
                Thread.Sleep(10);
            var available = socket.Available;
            Debug.WriteLine("Network data: " + available.ToString() );
            if (available == 0) break;
            Debug.WriteLine("Network: " + socket.RemoteEndPoint.ToString());//<----Error happens here.
            socket.Receive(data);
            name = Encoding.UTF8.GetString(data, 374, 24);
            Debug.WriteLine(name);
    catch (Exception ex)
        Debug.WriteLine("Network: " + ex.Message);
Try reading the packet before looking at the endpoint. It is possible that there are several packets in the buffer.Therefore, you need a context (a read packet) to get the remote address.
Thanks for the suggestion, it led me to the following code that appears to work. Used ReceivedFrom(), I passed the EndPoint created from the existing IPEndPoint and on return it updated it with the client IP address and port. (There was a fair bit of “googling” to get there as well.)
    int port = 5556;
    string name;
    try
                Thread.Sleep(10);
            EndPoint ep = (IPEndPoint)ipEndPoint;
            socket.ReceiveFrom(data,ref ep);
            Debug.WriteLine("From IP: " + ep.ToString());
Does it work twice?
It picks up all 4 devices that are broadcasting on the network as it should. They broadcast every second.
