I’d like to import MIDI data to the UART.
Following the schema at Specs should be very easy to implement, but the problem migth be the serial setting.
Midi uses a serial asychronous protocol, running at 31,250 baud. It sends a 10-bit frame consisting of a start bit, 8 bits of data (from LSB to MSB), and a stop bit.
Using NETMF (with the emulator) give me an error if I set a baud rate that has a non-standard value, and more than this I have no idea on how to set the start bit.
Is it possible to resolve this issue or I have to give up with NETMF and use some different approach ?
