I tried the following test codes for sending data from PC to G120 development board COM1, and echo back the same data from G120 to PC.
But, all of the echo back data are DEC number as string instead of ASCII string.
For example, I open up TerraTerm, when sending “A” from PC to G120, G120 returned “65” (this is NOT number, this is 2bytes strings (0x36,0x35),)
using GHI.Pins;
using System.IO.Ports;
using System.Text;
namespace NETMFTest
SerialPort UART = new SerialPort("COM1", 115200);
int read_cnt = 0;
byte[] rx_data = new byte[1];
UART.Open();
read_cnt = UART.Read(rx_data, 0, 1);
if (read_cnt > 0)
string get_data = rx_data[0].ToString() +"\r\n";
byte[] buffer = Encoding.UTF8.GetBytes(get_data);
UART.Write(buffer, 0, buffer.Length);
Thread.Sleep(10);
I want to get the string.
Appreciate your help.
