I have a problem with the uart BytesToRead function.
I have a sensor that is streaming data into a SCM20260D Dev board. The sensor output is RS422
connected to a RS485 Click.
The SCM20260D/Click does not transmit only ever receives and is forced to receive mode.
BaudRate = 921600 8N1
The relavent part of the program is below with the full simple program at the end of the post
Timer serial_poll_tmr = new Timer(serial_poll_tmr_callback, true, 500, 500);
void serial_poll_tmr_callback(object data)
int bytes_in_buffer = 0;
bytes_in_buffer = serial_1.BytesToRead;
Debug.WriteLine("Bytes in buffer - " + bytes_in_buffer.ToString());
serial_1.ClearReadBuffer();
If I set the timer to 10 mS everything works as I would expect the debug output looks like:
Bytes in buffer - 60
Bytes in buffer - 57
Similarly if I set the timer to 20 mS everything still looks ok:
Bytes in buffer - 120
Bytes in buffer - 119
If I stretch the timer to 1000 mS allowing the uart buffer to fill I get the following debug output.
Bytes in buffer - 750
Bytes in buffer - 0
Bytes in buffer - 0
Bytes in buffer - 0
The two questions I cant resolve are:
Why the buffer only reports 75% of size when full
(I have set the buffer size to 1000 bytes if I change the buffer size to 500 it reports 375) . -
Why every second poll does it report 0?
Any thoughts would be greatly appreciated.
I have searched the forum posts but haven’t found anything relavent. If I have missed something I apologize.
As an aside if I actually read the data every 20 mS it is as it should be. The data value I
extract does not need to be updated more than once a second and I am reluctant to use
system resources where unnecessary.
VS2019
All assemblies are 2.1.0.0
SCM20260D Dev Firmware 2.1.0.6400
The complete “simple” program is:
using System.Collections;
using System.Diagnostics;
using System.Text;
using GHIElectronics.TinyCLR.Devices.Uart;
namespace Serial_Port_Test
class Program
static void Main()
//Force serial port to receive mode *********************************
var gpioController = GpioController.GetDefault();
GpioPin read_control_output = gpioController.OpenPin(SC20260.GpioPin.PI0);
read_control_output.SetDriveMode(GpioPinDriveMode.Output);
read_control_output.Write(GpioPinValue.Low);
//Configure Serial Port
var serial_1 = UartController.FromName(SC20260.UartPort.Uart8);
var uartSetting = new UartSetting()
BaudRate = 921600,
DataBits = 8,
Parity = UartParity.None,
StopBits = UartStopBitCount.One,
Handshaking = UartHandshake.None,
serial_1.SetActiveSettings(uartSetting);
serial_1.ReadBufferSize = 1000;
serial_1.Enable();
Timer serial_poll_tmr = new Timer(serial_poll_tmr_callback, true, 1000, 1000);
Thread.Sleep(5000);
