Which is the buffer size of Fez Cobra’s UART? I’m using the same code in a Net Framework 4 windows app and in a NETMF 4.1 app, and when I send lots of datas in a very short time, windows app is working properly, but in my Fez doesn’t it.
I know that the serial port buffer in Windows (and Mac OS) is limited in size to 10 Kbytes, but what about Fez Cobra?
Thanks!!
PD: I’ve been looking for it in EMX User Manual, and have not found anything.
The problem is that I’m not receiving some frames. I also have to say that I check that all frames begin by a special byte and have the right checksum.
All this is in the same method so this is because the 150 lines.
In the past, when others have had difficulty with framed serial data, it has usually been a problem with how they were handling the data stream.
It should not take 150 lines to just read a frame. Refactor your code to do the frame reading in a standalone method, and post that method. It is good programming practice to encapsulate specific functionality instead of having a large monolith program.
That loop is constantly newing streams and arrays. Seems like you make it more complex then needed.
You have a description of that protocol somewhere? Because it’s hard to figure out from the code…
I have made some generic example in notepad, so it will not compile but it gives you a total different view on how you could handle it more efficient. I didn’t implement the ProcessPacket method called by the ReceivedData thread proc, I’ll leave that up to you.
In the example code here I detect and capture packets without newing anything. Also, open the serial port before the loop and close it after the loop. Don’t do this in the receive loop that needs to be as tight as possible.
private void ReceiveData()
byte[] buffer = new byte[1024]; // Make sure this buffer is large enough to hold a full packet
int bytesInBuffer = 0;
int startOfPacket = -1;
_serialPort = new SerialPort(_port, _baudRate);
_serialPort.Open();
while (!_stopThd)
while (_serialPort.BytesToRead > 0)
int bytesRead = _serialPort.Read(buffer, bytesInBuffer, buffer.Length - bytesInBuffer);
if (bytesRead <= 0)
break;
// Search PACKET_STARTBYTE in newly received data
if (startOfPacket == -1)
startOfPacket = Array.IndexOf(buffer, EpiZBResponse.PACKET_STARTBYTE, bytesInBuffer);
// Update number of bytes in buffer
bytesInBuffer += bytesRead;
// Throw away data before PACKET_STARTBYTE
if (startOfPacket > 0)
bytesInBuffer -= startOfPacket;
if (bytesInBuffer > 0)
Array.Copy(buffer, startOfPacket, buffer, 0, bytesInBuffer);
if ((startOfPacket == 0) && (bytesInBuffer >= ACCEPTABLE))
int bytesConsumed;
ProcessPacket(buffer, bytesInBuffer, out bytesConsumed);
// Throw away consumed bytes by ProcessPacket
bytesInBuffer -= bytesConsumed;
startOfPacket = -1;
Thread.Sleep(20);
_serialPort.Close();
I have also refactored your code, now you can analizy my sample and Wouters. I also don’t create any new buffers, just operate on one byte array. My sample should work if you add your protocol logic.
using System.IO.Ports;
namespace FEZ_Domino_Application1
private static SerialPort _serialPort;
private static string _port;
private static int _baudRate;
private static int _bufferCount;
private static byte[] _buffer;
_port = "COM1";
_baudRate = 9600;
_buffer = new byte[1024];
_serialPort.Open();
_serialPort.DataReceived += (sender, args) => ReceiveData();
private static class EpiZBResponse
public const byte PACKET_STARTBYTE = 0x01;
private static void ReceiveData()
try
_bufferCount += _serialPort.Read(_buffer, _bufferCount, _serialPort.BytesToRead);
var offset = -1;
offset = Array.IndexOf(_buffer, EpiZBResponse.PACKET_STARTBYTE, offset + 1);
// no start byte
if (offset == -1)
_bufferCount = 0;
return;
var remainingCount = _bufferCount - offset;
if (!IsLengthOk(_buffer, offset, remainingCount))
Debug.Print("Not enough bytes, waiting for more");
return;
var length = GetLength(_buffer, offset);
Debug.Print(CheckSum(_buffer, offset)
? HexHelper.ToHex(_buffer, offset, length)
: "Invalid checksum");
offset += length - 1;
catch (Exception e)
Debug.Print("Exception while handling received data. " + e);
private static bool IsLengthOk(byte[] data, int offset, int avilableBytes)
// length is ok if the value is less or equal to available byte avilableBytes
return avilableBytes > 1 && GetLength(data,offset) <= avilableBytes;
private static int GetLength(byte[] data, int offset)
// i assume the second byte is the length of whole frame
return data[offset + 1];
private static bool CheckSum(byte[] data, int offset)
// i assume the checksum is the last byte and value equals to 0xFF
return data[offset + GetLength(data,offset) - 1] == 0xFF;
public static class HexHelper
const string Hex = "0123456789ABCDEF";
public static string ToHex(byte[] data, int offset, int count)
var result = string.Empty;
for (var i = 0; i < count; i++)
result += ToHex(data[offset + i]);
return result;
public static string ToHex(byte b)
return new string(new[] { Hex[b >> 4], Hex[b & 0x0F] });
@ Gralin: your buffer will overflow when serial data keeps comming. Those return statements will exit the thread instead of breaking the while (true) loop
