uAlfat File System Simulator
We’ve used the uAlfat chip for years for our real-time applications. I’m currently in the process of porting our code to the tinyCLR environment and SITCore chipset, however, it’s taking longer then expected as C# is more of a learning curve from C then I expected.
In the meantime I was going to use the uAlfat File System Simulator but according to the code it uses the SITCore SC20260. Is this the only chipset the File System Simulator will work on or can it work on your smaller chipsets with a few minor changes?
All chips work very similarly as the all share the same tinyclr OS.
I’m assuming that I just change the chipset allocation in the program and verify the control pinouts are valid and it should work? Is there anything else I should be concerned about? Thank you.
Just keep in mind that the smallest one (SC13) does not have File System. You need SC20 family.
We are available to help with software and hardware changes if that helps.
Here is another option
