hy i wanted to use two motorController L298 to control 4 Motors ( each motorController controls 2 motors). But if i use
do i use the MotorControllerL298 from the motorControllerL298_1 ??
because i have two motorControllerL298 (motorControllerL298_1 &motorControllerL298_2) and just one MotorController. (MotorControllerL298)
here is the Code i want to use (to fly a Quadocopter)(for example I use here a Joystick to control it):
```cs
int speed2Y = (((Convert.ToInt32(joystick2.GetPosition().Y.ToString())) + 1) / 2);
motorControllerL298_1.MoveMotor(MotorControllerL298.Motor.Motor1, speed2Y);
motorControllerL298_1.MoveMotor(MotorControllerL298.Motor.Motor2, speed2Y);
motorControllerL298_2.MoveMotor(MotorControllerL298.Motor.Motor1, speed2Y);
motorControllerL298_2.MoveMotor(MotorControllerL298.Motor.Motor2, speed2Y);
are all MotorControllerL298 the same or do they inherit it from motorControllerL298_1 or _2??
thank you for your HELP
greets
cacciu
