I’m getting a “500 Internal Server Error” for all NETMF tutorial pages…?
-Scott
-Scott
I have tried several all work fine.Which are not working for you?
Every link I try gives the error. Tried using a different computer - no luck. Might be an issue with firewall at work?
-Scott
It is possible.
Here’s what I get from any link I click on in the NETMF tutorial section:
A database query syntax error has occurred. This may indicate a bug in the software. The last attempted database query was:
(SQL query hidden)
from within function “User::addToDatabase”. MySQL returned error “1048: Column ‘user_email’ cannot be null (localhost)”.
I seem to recall viewing these from work before, so this seems a bit weird.
-Scott
Sounds like like your user information (email) got corrupted. I am sure somebody (Josh) from GHI will look into that.
It should work now so keep this thread updated.
Okay, it didn’t work, so I tried logging out on my other computer. Once logged out, the tutorials worked fine.
However, I could not log back in from the wiki.tinyclr.com page!!! I got a similar SQL error saying the username cannot be null. When I went to the tinyclr.com page and tried the login in the menu bar, it worked fine. BUT - I was once again unable to view any tutorials!
So it appears that my account is somehow corrupt. It must have happened when I updated my avatar earlier today.
Hope you can help!
Thanks,
Scott
It’s worth another try.
It’s working now - thanks!
Scott
