I am using Windows 10 pro,64 bit on an iMac running bootcamp, i7-4771 cpu @ 3.5Ghz, 32GB memory, all usb3 ports.
I have the Brain Pad .NET Rev 1.1. I have installed VS 2013.
I see two firmware images BrainPad 4.3.7, and BrainPad 4.3.8
The Scratch Gateway, say BrainPad v4.3.7 is installed
Click Deploy, I get:
Deploying BrainPad v4.3.7 to G30_G30
Deploying assemblies…
Incrementally deploying assemblies to device
All assemblies on the device are up to date. No assembly deployment was necessary.
Assemblies successfully deployed to device.
Rebooting device…
On the BrainPad Display, I see:
Scratch4.Net Firmata Server
by Pervasive Digital LLC
Server v1.2.0.0
Protocol v2.4.3
http://www.scratch4.net/
Debug.Deploy Mode enabled (after pressing left button)
Now I try the Scratch 2 Offline Editor,
shift, file click, Select import experimental HTTP extension,
select, BrainPad-437.s2e
create the script as in Figure 11 in The BrainPad Scratch Introduction
press the left buttion and nothing happens.
What am I doing wrong?
How does the script get downloaded over the USB cable (on usb3 port)?
Is Windows 10 the problem? USB3 the problem? using a USB3 hub the problem?
I do see a yellow button on the Scripts panel next the “BrainPad Extensions”
When I click on it, it says “No .Net Micro Framework board is connected”
But the BrainPad Red power LED is lit, and the Display has the above text(…Debug.Deploy enabled)
