Main Site Documentation
Try-Catch in constructor NETMF
#1
NetMF 4.3. G30 SoC
Is it okay to have a try-catch in an object’s constructor?
MyObject InstanceOfMyObject = new MyObject(9999); // the caller
class MyObject
    private byte[] A;
    public MyObject(ushort Size)
        try
            A = new byte[Size]; // might throw an error
        catch
            // what do I do here?
            // How do I delete this non-initialized object?
            // What will be returned to the caller?
#2
If you can’t recover in the catch area, then you should re-throw the exception.
You could also have a success flag that says object was properly created.
#3
Use a factory method and move the try/catch there.
class Foo {
    public void Bar() {
        var bla = MyObject.TryCreate(9999);
        // now need to handle the case where 'bla' is null!
class MyObject {
    public static MyObject TryCreate(ushort size) {
        MyObject obj;
        try {
            // it is a good practice to keep content of try clause as narrow
            // as possible to not accidentially catch more than what's intended
            obj = new MyObject(size);
        } catch (OutOfMemoryException) { // only catch specific types of exceptions
            // not enough memory
            return null;
        return obj;
    private byte[] _array;
    // private constructor ensures that only TryCreate can be used to create a MyObject
    private MyObject(ushort size) {
        _array = new byte[size]; // might throw an error
Hope this helps.
#4
Thanks @Banjobeni and @Mike
I had heard of a factory before but never thought I needed one until now. This did the trick.
And checking if the returned reference is null does the job of the “success flag” well.
#5
How do you feel about this all being inside the class itself?
Here is the beginning of a new class I am creating:
class CriticalTransactionTimer
    public static delegate void Callback();
    public uint Timeout_s { get; private set; }
    public uint NumberOfRetries { get; private set; }
    private Callback ElapsedCallback;
    private Callback FailureCallback;
    public static CriticalTransactionTimer TryCreateTimer(uint timeout_s, uint numberOfTries, Callback OnTimerElapsed, Callback OnFailure)
        CriticalTransactionTimer returnVal;
        try
            returnVal = new CriticalTransactionTimer(timeout_s, numberOfTries, OnTimerElapsed, OnFailure);
        catch ( OutOfMemoryException )
            returnVal = null;
            if(OnFailure != null)
                OnFailure();
        return returnVal;
    private CriticalTransactionTimer(uint _timeout_s, uint _numberOfTries, Callback _OnTimerElapsed, Callback _OnFailure)
        // actual construction
