Hi all!
I have installed the October 24th release of .NET Gadgeteer package. I have successfully updated the firmware of my FEZ Spider to version 4.2.5.0. However, if I try the following code to connect to Wi-Fi network:
if (!wifi_RS21.Interface.IsOpen)
wifi_RS21.Interface.Open();
if (!wifi_RS21.Interface.NetworkInterface.IsDhcpEnabled)
wifi_RS21.Interface.NetworkInterface.EnableDhcp();
NetworkInterfaceExtension.AssignNetworkingStackTo(wifi_RS21.Interface);
wifi_RS21.Interface.WirelessConnectivityChanged += new WiFiRS9110.WirelessConnectivityChangedEventHandler(Interface_WirelessConnectivityChanged);
wifi_RS21.Interface.NetworkAddressChanged += new NetworkInterfaceExtension.NetworkAddressChangedEventHandler(Interface_NetworkAddressChanged);
wifi_RS21.NetworkDown += new GTM.Module.NetworkModule.NetworkEventHandler(wifi_RS21_NetworkDown);
wifi_RS21.NetworkUp += new GTM.Module.NetworkModule.NetworkEventHandler(wifi_RS21_NetworkUp);
WiFiNetworkInfo[] ScanResp = wifi_RS21.Interface.Scan("myAP");
if (ScanResp != null && ScanResp.Length > 0)
wifi_RS21.Interface.Join(ScanResp[0], "myPWD");
void wifi_RS21_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("NetworkUp event!");
void wifi_RS21_NetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("NetworkDown event!");
void Interface_WirelessConnectivityChanged(object sender, WiFiRS9110.WirelessConnectivityEventArgs e)
Debug.Print("WirelessConnectivityChanged event!");
Debug.Print("Connected: " + e.IsConnected);
Debug.Print("IP Address : " + wifi_RS21.Interface.NetworkInterface.IPAddress);
void Interface_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("NetworkAddressChanged event!");
I always obtain the following result:
Using mainboard GHI Electronics FEZSpider version 1.0
RS9110 firmware version Number is 4.4.5
RS9110 driver version Number is 4.4.5
Program Started
NetworkDown event!
Connected: True
IP Address : 0.0.0.0
And nothing else.
In particular, the application tells me that network is connected, but IP Address is always 0.0.0.0.
Instead, if I use a FEZ Spider with .NET Micro Framework 4.1 and the April .NET Gadgeteer Package, I manage to correctly connect to Wi-Fi and to obtain a valid IP address, so the problem isn’t related to the network.
What am I doing wrong?
Thanks in advance for the attention.
