In these days I’m working with Mountaineer Ethernet Mainboard and I have a problem with the Ethernet port. I’m using .NET Micro Framework 4.2 QFE1.
When I call the UseDHCP method on the ethernetForMountaineerEth module added in the Designer, the NetworkUp event is immediately raised, and the IsNetworkUp and IsNetworkConnected properties return both true. However, the ethernetForMountaineerEth.NetworkSettings.IPAddress property contains “0.0.0.0”. The DHCP server on my network is working correctly, in fact I can use it with FEZ Spider with no problem.
If, on the other hand, I call UseStaticIP, everything works fine: I’m able to setup a web event and invoke it using a Web Browser.
we investigated the problem. It looks like the IsNetworkConnected property is not yet implemented, and the UseDHCP() function does not work. The board actually gets an IP Address through DHCP, but loses it when UseDHCP() is called, apparently because of the RenewDchpLease() function. This is not a Gadgeteer problem and can be reproduced with a plain NETMF application, calling RenewDhcpLease() directly.
Does it work when you remove the call to UseDHCP? DHCP itself should work, we had no problems with it so far.
Or could you work with static IP addresses for the time being?
I have asked about the issue because, as I promised you, I’m writing some reviews that will be published on http://mikedodaro.net, so I need to know what was the origin of the problem, to understand if it was my mistake.
