I’m trying to use the 3rd I2C channel on my custom STM32F4 board.
I changed my platform_selector.h to use Port 3 (I also wish this was changed to read Channel instead of Port)…
#define STM32F4_I2C_PORT     3
#define STM32F4_I2C_SCL_PIN  {8} // PA8
#define STM32F4_I2C_SDA_PIN  {41} // PC9
Reading in “STM32F4_i2c_functions.cpp” I noticed I should be using PC9 and PA8…
#elsif STM32F4_I2C_PORT == 3
#define I2Cx                   I2C3
#define I2Cx_EV_IRQn           I2C3_EV_IRQn
#define I2Cx_ER_IRQn           I2C3_ER_IRQn
#define RCC_APB1ENR_I2CxEN     RCC_APB1ENR_I2C3EN
#define RCC_APB1RSTR_I2CxRST   RCC_APB1RSTR_I2C3RST
#if !defined(STM32F4_I2C_SCL_PIN)
#define STM32F4_I2C_SCL_PIN  8 // PA8
#endif
#if !defined(STM32F4_I2C_SDA_PIN)
#define STM32F4_I2C_SDA_PIN  41 // PC9
#endif
I have a scope connected to SDA/SCL and I’m not seeing anything when I execute my I2C code. Any thoughts?
If I manually set the pins high or low of course I see the activity I expected on the scope.
My C# code is this simple…
I2CDevice.Configuration config = new I2CDevice.Configuration(0x51, 50);
I2CDevice ic2Device = new I2CDevice(config);
buffer = new byte[] { 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA };
readBuffer = new byte[] { 0x00, 0x00 };
I2CDevice.I2CWriteTransaction write = I2CDevice.CreateWriteTransaction(buffer);
I2CDevice.I2CReadTransaction read = I2CDevice.CreateReadTransaction(readBuffer);
r = ic2Device.Execute(new I2CDevice.I2CTransaction[] { write, read }, 1000);
if (r != 0)
//Never happens
