I am following the steps here to update the Firmware for a FEZ Hydra:
Everything works until I run MFDeploy 4.1. MFDeploy sees the FEZ Hydra as a USB device, but I can’t deploy the firmware or ping the device. I tried on 2 seperate computers and I am getting the same problem.
Ok finally we have another confirmation of this problem the other mike is having. There seem to be a bug in USB that we are not able to reproduce here!
What do we need to do to repro here? We tried many pcs and many laptops. All worked fine!
I kept digging at this and was able to replicate the behaviour 2 times over serveral tests. When I ran into the issue the boot was fine and the LCD displayed the correct firmware numbers and the 'waiting for … ’ message. However I was not able to ping from MFDeploy or deploy from Visual Sudio.
I went through the entire cycle of erase. Still MFDeploy could not ping.
Restarting the Windows (Win7 64Bit) puts things in order. I was able to ping and flash the firmware.
Please try a restart to see if it helps.
It looks like there is a glitch with the USB firmware or the driver.
The behaviour can be reproduced by repeating
[italic]**Initial state : I had the original firmware that was on the Hydra when it was shipped to me on 11/09/2011. This was the very first firmware.
I did connect the Hydra to the computer multiple time prior to erasing and updating the new firmware.
[/italic]
1.Open Visual Studio
2.Create a simple app
3.Deploy/Debug
4.Stop debugging
5.Reset Hydra
6.Let the deployed app. run for a while
7.Deploy/Debug from Visual Studio
8.Stop debugging
9.Reset Hydra
10.Let the deployed app. run for a while
11.Unplug Hydra
12.Wait a while
13.Close Visual Studio
14.Ping from MFDeploy
You may have to repeat these steps multiple times.
I did a cold boot and that did the trick. I also ensured that the USB cable was very short (less than 6 inches) and attached directly to the mother/logic board of the computer.
