In Cobra II project, I am trying to make my device fault tolerant by handling network socket exceptions and keep the code running after an exception. Upon getting a network exception, I want to shut down the ENC28 module and restart it. I get an exception when I try to shut down the ENC28, my shutdown function OnDisconnect() causes a pop up message window in Visual Studio, saying this:
“An unhandled exception of type ‘System.Exception’ occurred in GHI.Premium.Net.dll
Additional information: NetworkEventFlags: This should never happen!”
My shutdown code does this:
using GHINET = GHI.Premium.Net;
private GHINET.EthernetENC28J60 eth;
private void OnDisconnect(object sender, EventArgs e)
try
if ( eth != null)
GHINET.NetworkInterfaceExtension.AssignNetworkingStackTo(null);
if ( eth.IsOpen ) eth.Close();
eth.Dispose();
eth = null;
catch (Exception ex)
Debug.Print("OnDisconnect() exception " + ex.Message);
My startup code does this:
private NetworkInterface StartClient()
NetworkInterface ni = null;
try
eth = new GHINET.EthernetENC28J60(SPI.SPI_module.SPI2, Pin.P1_10, Pin.P2_11, Pin.P1_9, 4000);
eth.NetworkAddressChanged += new NetworkInterfaceExtension.NetworkAddressChangedEventHandler(eth_NetworkAddressChanged);
if (!eth.IsOpen) eth.Open();
ni = eth.NetworkInterface;
ni.EnableStaticIP(StaticIP, NetMask, GatewayAddress);
ni.EnableStaticDns(new string[] { PrimaryDNS, SecondaryDNS });
Debug.Print("Static IP enabled.");
Debug.Print("IP address = " + ni.IPAddress);
Debug.Print("Gateway address = " + ni.GatewayAddress);
Debug.Print("Subnet mask = " + ni.SubnetMask);
foreach (string address in ni.DnsAddresses)
Debug.Print("DNS address = " + address);
GHINET.NetworkInterfaceExtension.AssignNetworkingStackTo(eth);
Debug.Print("Start Client() exception " + ex.Message);
return ni;
How can I shut down and re-start the GHI.Premium.Net.EthernetENC28J60 in Cobra II after a socket exception?
