I need to build a WCF server to receive file from client. But I don’t know how?
can any one give me some instruction or some example?
thx in advance.
thx in advance.
.NET MF does not support WCF.
Maybe we meant DPWS. Aren’t these related?
oh, yes, I mean DPWS.
But I need a client on PC, which will have a WCF client.
Do you have any suggestion or sample? will it be slow to use DPWS?
There are examples in my documents folder but I suggest not to use it if you do not have to.
To Gus:
Thx for your reply, but I can’t find your example.
To Mike:
In fact, I created a DPWS service on board and also a client WCF on PC. I used a HTTP binding. When I transfer file to the device, the speed is super slow. As I need to send a file of 3M, it took more than one hour. Even I set the Oneway property true.
So do you have any suggestion on that?
C:\Users\Gus Issa\Documents\Microsoft .NET Micro Framework 4.1\Samples
Hi Gus:
Sorry for mis-understanding you. But none of the samples is for transferring file. Only a DPWS service. I also followed this sample to build a service on my board. The current problem is that I can’t transfer a file quickly, the speed is terribly slow.
below is my code:
server :
ProtocolVersion version = new ProtocolVersion10();
WS2007HttpBinding binding = new WS2007HttpBinding(new HttpTransportBindingConfig(guid, 8084));
Device.Initialize(binding, version);
//processing file received, I read a file into bytes, and send bytes of 1024 each time
partial class ChipworkxServiceImplement
private string _PreviousFileName = "";
private string _BaseDir;
private FileStream _FileStream;
private int _TotalWriteCount = 0;
public string BaseDir
set { _BaseDir = value; }
get { return _BaseDir; }
public ChipworkxServiceImplement()
_BaseDir = "\\SD";//"\\ROOT"
public UploadFileResponse UploadFile(StreamObject req)
if (_PreviousFileName == null || _PreviousFileName != req.FileName)
_PreviousFileName = req.FileName;
if (_FileStream != null)
_FileStream.Close();
string pathName = Path.Combine(_BaseDir, _PreviousFileName);
_FileStream = new FileStream(pathName, FileMode.Create);
_FileStream.Write(req.FileData, 0, req.FileData.Length);
else if (_PreviousFileName == req.FileName)
if (req.FileData.Length == 4)
byte[] ending = new byte[] {req.FileData[0], req.FileData[1], req.FileData[2], req.FileData[3]};
int end = (ending[0] << 24) | (ending[1] << 16) | (ending[2] << 8) | (ending[3]);
if ((end & 0xFF) == 0xFF)
return new UploadFileResponse(); //
Yes I meant those examples as a starting point. I never used this feature myself.
