Touch C8 not in Gadgeteer toolbox
Just got a Touch C8. Is there an update to Gadgeteer that will enable this module? I downloaded the latest but I can’t add it to my gadgeteer project. Alternatively, Is there a manual way to use it with plain old .Net MF 4.2?
Nevermind. It was introduced after the latest release. Probably going to be in the next release.
Yes it will be in the new SDK (coming very soon), here is the driver
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
namespace Gadgeteer.Modules.GHIElectronics
	/// <summary>
	/// A multi-function touch sensor for .Net Gadgeteer.
	/// </summary>
	public class TouchC8 : GT.Modules.Module
		private const ushort I2C_ADDRESS = 0x2B;
		private const int I2C_CLOCK_RATE = 100;
		private const byte IRQ_SRC = 0x0;
		private const byte CAP_STAT_MSB = 0x1;
		private const byte CAP_STAT_LSB = 0x2;
		private const byte WHL_POS_MSB = 0x3;
		private const byte WHL_POS_LSB = 0x4;
		private const byte WHEELS = 8;
		private GT.Socket socket;
		private GTI.I2CBus device;
		private GTI.InterruptInput interrupt;
		private GTI.DigitalOutput reset;
		private byte[] readBuffer;
		private byte[] writeBuffer;
		private byte[] addressBuffer;
		private Direction previousWheelDirection;
		private double previousWheelPosition;
		private bool previousWheelTouched;
		private bool previousButton0Touched;
		private bool previousButton1Touched;
		private bool previousButton2Touched;
		private bool previousButton3Touched;
		/// <summary>
		/// Represents the buttons on the sensor.
		/// </summary>
		public enum Buttons
			/// <summary>
			/// The up button.
			/// </summary>
			Up = 0x2,
			/// <summary>
			/// The middle button.
			/// </summary>
			Middle = 0x4,
			/// <summary>
			/// The down button.
			/// </summary>
			Down = 0x8
		/// <summary>
		/// Represents the direction of motion on the wheel.
		/// </summary>
		public enum Direction
			/// <summary>
			/// Clockwise motion
			/// </summary>
			Clockwise,
			/// <summary>
			/// Counterclockwise motion
			/// </summary>
			Counterclockwise
		/// <summary>
		/// Delegate representing the proximity detected event.
		/// </summary>
		/// <param name="sender">The sensor that the detection occured on.</param>
		/// <param name="state">Whether or not an object is near the sensor.</param>
		public delegate void PromixityDetectedHandler(TouchC8 sender, bool state);
		/// <summary>
		/// Delegate representing the button touch event.
		/// </summary>
		/// <param name="sender">The sensor that the event occured on.</param>
		/// <param name="button">The button that the event occured on.</param>
		/// <param name="state">Whether or not the button was pressed or released.</param>
		public delegate void ButtonTouchHandler(TouchC8 sender, Buttons button, bool state);
		/// <summary>
		/// Delegate representing the wheel touch event.
		/// </summary>
		/// <param name="state">Whether or not the wheel was pressed or released.</param>
		public delegate void WheelTouchHandler(TouchC8 sender, bool state);
		/// <summary>
		/// Delegate representing the wheel position changed event.
		/// </summary>
		/// <param name="position">The position of the touch on the wheel.</param>
		/// <param name="direction">The direction of the touch on the wheel.</param>
		public delegate void WheelPositionChangedHandler(TouchC8 sender, double position, Direction direction);
		/// <summary>
		/// Fires when the proximity sensor detects an object.
		/// </summary>
		public event PromixityDetectedHandler OnProximityEnter;
		/// <summary>
		/// Fires when the proximity sensor no longer detects an object after detecting one.
		/// </summary>
		public event PromixityDetectedHandler OnProximityExit;
		/// <summary>
		/// Fires when a button is pressed.
		/// </summary>
		public event ButtonTouchHandler OnButtonPressed;
		/// <summary>
		/// Fires when a button is released.
		/// </summary>
		public event ButtonTouchHandler OnButtonReleased;
		/// <summary>
		/// Fires when the wheel is pressed.
		/// </summary>
		public event WheelTouchHandler OnWheelPressed;
		/// <summary>
		/// Fires when the wheel is released.
		/// </summary>
		public event WheelTouchHandler OnWheelReleased;
		/// <summary>
		/// Fires when the position of the touch on the wheel changes.
		/// </summary>
		public event WheelPositionChangedHandler OnWheelPositionChanged;
		private PromixityDetectedHandler OnProximity;
		private ButtonTouchHandler OnButton;
		private WheelTouchHandler OnWheel;
		private WheelPositionChangedHandler OnWheelPosition;
		private void OnProximityEvent(TouchC8 sender, bool state)
			if (this.OnProximity == null)
				this.OnProximity = new PromixityDetectedHandler(this.OnProximityEvent);
			if (Program.CheckAndInvoke(state ? this.OnProximityEnter : this.OnProximityExit, this.OnProximity, sender, state))
				if (state)
					this.OnProximityEnter(sender, state);
					this.OnProximityExit(sender, state);
		private void OnButtonEvent(TouchC8 sender, Buttons button, bool state)
			if (this.OnButton == null)
				this.OnButton = new ButtonTouchHandler(this.OnButtonEvent);
			if (Program.CheckAndInvoke(state ? this.OnButtonPressed : this.OnButtonReleased, this.OnButton, sender, button, state))
				if (state)
					this.OnButtonPressed(sender, button, state);
					this.OnButtonReleased(sender, button, state);
		private void OnWheelEvent(TouchC8 sender, bool state)
			if (this.OnWheel == null)
				this.OnWheel = new WheelTouchHandler(this.OnWheelEvent);
			if (Program.CheckAndInvoke(state ? this.OnWheelPressed : this.OnWheelReleased, this.OnWheel, sender, state))
				if (state)
					this.OnWheelPressed(sender, state);
					this.OnWheelReleased(sender, state);
		private void OnWheelPositionEvent(TouchC8 sender, double position, Direction direction)
			if (this.OnWheelPosition == null)
				this.OnWheelPosition = new WheelPositionChangedHandler(this.OnWheelPositionEvent);
			if (Program.CheckAndInvoke(this.OnWheelPositionChanged, this.OnWheelPosition, sender, position, direction))
				this.OnWheelPositionChanged(sender, position, direction);
		/// <summary>
		/// Constructs a new TouchC8 sensor.
		/// </summary>
		/// <param name="socketNumber">The socket number the sensor is plugged into.</param>
		public TouchC8(int socketNumber)
			this.readBuffer = new byte[1];
			this.writeBuffer = new byte[2];
			this.addressBuffer = new byte[1];
			this.socket = GT.Socket.GetSocket(socketNumber, false, this, "I");
			Thread.Sleep(1000);
			this.reset = new GTI.DigitalOutput(this.socket, GT.Socket.Pin.Six, true, this);
			Thread.Sleep(1000);
			this.Reset();
			Thread.Sleep(1000);
			this.device = new GTI.I2CBus(this.socket, TouchC8.I2C_ADDRESS, TouchC8.I2C_CLOCK_RATE, this);
			Thread.Sleep(1000);
			this.interrupt = new GTI.InterruptInput(socket, GT.Socket.Pin.Three, GTI.GlitchFilterMode.Off, GTI.ResistorMode.PullUp, GTI.InterruptMode.FallingEdge, this);
			this.interrupt.Interrupt += new GTI.InterruptInput.InterruptEventHandler(OnInterrupt);
			this.previousWheelDirection = (Direction)(-1);
			this.previousWheelPosition = 0;
			this.previousWheelTouched = false;
			this.previousButton1Touched = false;
			this.previousButton2Touched = false;
			this.previousButton3Touched = false;
			Thread.Sleep(1000);
			this.ConfigureSPM();
		/// <summary>
		/// Gets whether or not the given button is being touched by the user
		/// </summary>
		/// <param name="button">The button to check.</param>
		/// <returns>Whether or not the given button is being touched.</returns>
		public bool IsButtonPressed(Buttons button)
			return (this.ReadRegister(TouchC8.CAP_STAT_LSB) & (byte)button) != 0;
		/// <summary>
		/// Gets whether or not the wheel is being touched by the user.
		/// </summary>
		/// <returns>Whether or not the wheel is being touched.</returns>
		public bool IsWheelPressed()
			return (this.ReadRegister(TouchC8.CAP_STAT_MSB) & 0x10) != 0;
		/// <summary>
		/// Gets whether or not the proximity detector is detecting a nearby object.
		/// </summary>
		/// <returns>Whether or not the sensor is detecting anything.</returns>
		public bool IsProximityDetected()
			return (this.ReadRegister(TouchC8.CAP_STAT_LSB) & 0x1) != 0;
		/// <summary>
		/// Gets the current position of the user on the wheel in degrees.
		/// </summary>
		/// <returns>The degree measure of the user's location on the wheel between 0 and 360.</returns>
		public double GetWheelPosition()
			ushort whlLsb = this.ReadRegister(TouchC8.WHL_POS_LSB);
			ushort whlMsb = this.ReadRegister(TouchC8.WHL_POS_MSB);
			double wheelPosition = (double)((whlMsb << 8) + whlLsb);
			return wheelPosition * (360.0 / (10.0 * TouchC8.WHEELS));
		/// <summary>
		/// Gets the current direction the user is moving on the wheel.
		/// </summary>
		/// <returns>The direction the user is moving.</returns>
		public Direction GetWheelDirection()
			return (this.ReadRegister(TouchC8.CAP_STAT_MSB) & 0x40) != 0 ? Direction.Clockwise : Direction.Counterclockwise;
		private void Reset()
			this.reset.Write(false);
			Thread.Sleep(100);
			this.reset.Write(true);
			Thread.Sleep(100);
		private void OnInterrupt(GTI.InterruptInput sender, bool value)
			byte flags = this.ReadRegister(TouchC8.IRQ_SRC);
			if ((flags & 0x8) != 0)
				double wheelPosition = this.GetWheelPosition();
				bool wheelTouched = this.IsWheelPressed();
				Direction wheelDirection = this.GetWheelDirection();
				if (wheelTouched != this.previousWheelTouched)
					this.OnWheelEvent(this, wheelTouched);
				if (wheelPosition != this.previousWheelPosition || wheelDirection != this.previousWheelDirection)
					this.OnWheelPositionEvent(this, wheelPosition, wheelDirection);
				this.previousWheelTouched = wheelTouched;
				this.previousWheelPosition = wheelPosition;
				this.previousWheelDirection = wheelDirection;
			if ((flags & 0x4) != 0)
				byte cap = this.ReadRegister(TouchC8.CAP_STAT_LSB);
				bool button0 = (cap & 0x1) != 0; //proximity
				bool button1 = (cap & 0x2) != 0;
				bool button2 = (cap & 0x4) != 0;
				bool button3 = (cap & 0x8) != 0;
				if (button0 != this.previousButton0Touched)
					this.OnProximityEvent(this, button0);
				if (button1 != this.previousButton1Touched)
					this.OnButtonEvent(this, Buttons.Up, button1);
				if (button2 != this.previousButton2Touched)
					this.OnButtonEvent(this, Buttons.Middle, button2);
				if (button3 != this.previousButton3Touched)
					this.OnButtonEvent(this, Buttons.Down, button3);
				this.previousButton0Touched = button0;
				this.previousButton1Touched = button1;
				this.previousButton2Touched = button2;
				this.previousButton3Touched = button3;
		private void ConfigureSPM()
			//SPM must be written in 8 byte segments, so that is why we have the extra stuff below.
			//0x4 is cap sensitivity mode, 0xFF to 0x55 are the cap type modes, 0x70 is cap 0 and 1 sensitivty, the last 3 0's set cap 2-7 sensitivity.
			this.WriteSPM(0x9, new byte[] { 0x4, 0xFF, 0xFF, 0x55, 0x70, 0x0, 0x0, 0x0 });
			//0x74 is to enable proximity sensing and the remaining values are the default reserved values that we cannot change
			this.WriteSPM(0x70, new byte[] { 0x74, 0x10, 0x45, 0x2, 0xFF, 0xFF, 0xFF, 0xD5 });
		private void WriteSPM(byte address, byte[] values)
			this.WriteRegister(0x0D, 0x10);
			this.WriteRegister(0x0E, address);
			this.addressBuffer[0] = 0;
			this.device.Write(Utility.CombineArrays(this.addressBuffer, values), 100); //needs to begin with a 0 representing the I2C address of 0.
			this.WriteRegister(0x0D, 0x00);
		private void WriteRegister(byte address, byte value)
			this.writeBuffer[0] = address;
			this.writeBuffer[1] = value;
			this.device.Write(this.writeBuffer, 100);
		private byte ReadRegister(byte address)
			this.addressBuffer[0] = address;
			this.device.WriteRead(this.addressBuffer, this.readBuffer, 100);
			return this.readBuffer[0];
@ Jeff - five seconds to instantiate?
Thanks!
I have a Cerbuino NET loaded with the latest FEZ Cerbuino with ethernet firmware. I created a .NET MF 4.2 console application. Added the Touch C8 Code. I get an invalid socket number expection with the following code in Main:
        private TouchC8 sensor;
            TouchC8 c8 = new TouchC8(2);
            c8.OnButtonPressed +=
                (sender, button, state) =>
                    Debug.Print(button.ToString() + " : " + state.ToString());
I know I’m missing something silly to get this working.
That driver needs a Gadgeteer project to work not just a Console application. Try Gadgeteer project template.
