Is there a way to handle the occurring of the RST TCP Flag during and after the TLS Handshake?
After The TCP “Server Hello Done” an RST Flag is sent and an error occurs.
The Following Packets are sent:
replace 192.168.86.64 by SITCore IP address.
Then you need to install cert.pem on PC with root trusted: There few ways to do, we tested the way below (for Window): Warning: The link below comes from third party, not GHI. Changing or installing certificate on your PC may affect to your PC’s security level, or causes your PC stop working.
When the certificate is installed correctly, everything works fine.
The only problem left is that the Server crashes when we try to connect to it when the certificate is not installed on the PC (also happens when we try your certificate).
We need the site working even if the certificate is not trusted by the browser. Is there a way to achieve that?
We could not reproduce the crash issue.
The way we reproduce is, generate new certificate by the command above, load to device, not installed anything to PC yet.
The application throws an exception as expected. From browser it says NET::ERR_CERT_AUTHORITY_INVALID
