TinyCLR v3 Is Here
TinyCLR v3 Is Here
The long stability run of TinyCLR v2 gave us room to focus on what mattered most for v3: a sharper development experience, modern .NET features, deeper networking, and tools that scale from a single board to a production line. Here’s what’s new­
Easy Upgrade Path
TinyCLR v3 is largely backward-compatible with v2. Most existing projects upgrade with little to no modification — the library API surface is intact, NuGet package names didn’t change, and the original GHIElectronics.TinyCLR.Devices.* APIs all still work. The full migration walkthrough is at docs.ghielectronics.com/tinyclr/migration.
Standard .NET IoT APIs, alongside the originals
GPIO, PWM, SPI, I²C, and Serial Port now offer two interface options:
  • The original GHIElectronics.TinyCLR.Devices.* APIs — your v2 code keeps compiling.
  • Microsoft’s standard System.Device.* (.NET IoT) APIs for portability with desktop .NET IoT applications.
Both ship in the same NuGet package. Install one and you get both — mix freely in the same project. The feature pages now show both side-by-side in tabbed examples.
RLP Is Back
You asked for it: Runtime Loadable Procedures (RLP) return in v3. Compile C functions into a small ELF file, load them onto the device at runtime, and call them from C# by name. Think of it as the embedded equivalent of calling a native DLL from desktop .NET — the convenience and safety of C# for your application, plus the raw speed of compiled C for the parts that need it.
Ideal for tight compute loops, DSP, image processing, microsecond-precision GPIO, and native interrupt handling. Ships with a Visual Studio project template and seven ready-to-run examples (speed, math, GPIO toggle, lookup tables, background tasks, events, button-driven interrupts).
Desktop Mode
Run TinyCLR code on a PC, before it ever touches hardware.
v3 includes a desktop support of mscorlib plus the TinyCLR networking and file-system libraries — so your business logic, parsers, state machines, network protocols, and storage code can be unit-tested and iterated on directly in Visual Studio on your development PC.
You get the full Visual Studio debugger experience, no device deployment cycle, no flashing — and the same code runs unchanged on SITCore when you’re ready. Pair it with a CI pipeline and you have automated regression testing for everything that doesn’t touch physical pins.
Generics Support
One of the most-requested v2 limitations, gone. v3 brings generic collections — List, Dictionary<TKey, TValue>, Stack, Queue — and you can write your own generic classes and methods. Cleaner code, fewer casts, no boxing for value types.
C# 11 language support
Modern C# — including top-level statements, target-typed new, file-scoped namespaces, and the rest of the C# 11 syntax — works on TinyCLR. Embedded code can finally look like the rest of your codebase.
Async / await
Task-based asynchronous programming is now first-class. async and await work the way they do on desktop .NET, dramatically simplifying network I/O, file operations, and any long-running work that used to require a hand-rolled thread.
.NET-compatible cryptography
The standard System.Security.Cryptography namespace is now available alongside the existing GHIElectronics.TinyCLR.Cryptography library. Same algorithms you’d reach for on desktop .NET — RSACryptoServiceProvider, AesCryptoServiceProvider, SHA256, HMACSHA256 — with no special embedded syntax.
Networking and XML Compatibility
Networking and XML APIs have been updated to align more closely with full .NET implementations, improving portability and reducing code differences between desktop and embedded applications.
.NET-compatible networking and XML
The networking and XML APIs have been updated to align more closely with full .NET. Code that worked against System.Net.Sockets, System.Net.Http, or System.Xml on the desktop now ports across with minimal changes — important for shared libraries between cloud services and embedded clients.
This includes several improvements:
  • Standard MQTT support — built on the same socket stack, integrates cleanly with Azure IoT Hub, AWS IoT, and any standard broker.
  • FTP client and server — file transfer over the network without rolling your own.
  • Multi-network-interface support — run WiFi and Ethernet and cellular concurrently, with routing between them.
  • Non-blocking socket operations for cleaner async code paths.
  • Reliability and performance fixes throughout the stack from real-world deployments.
Ethernet/IP Improvements
Extensive reliability, performance, and interoperability work across the entire EtherNet/IP stack — Scanner and Adapter sides both — based on field testing against industrial PLCs.
Graphics and UI
Better performance, better stability, smoother UI rendering. The same System.Drawing-style API you know, with v3 polish across native parallel and SPI virtual displays.
USB Host expansion
USB Host support has grown to cover:
  • USB cameras — capture frames from standard UVC webcams.
  • USB hubs — finally supported, so multi-device USB topologies just work.
Broader device compatibility across keyboards, mice, joysticks, and mass storage
TinyCLR Config CLI
TinyCLR Config now ships with a command-line interface alongside the GUI — script firmware flashing, deployment, and provisioning into your manufacturing and CI pipelines. No more clicking through dialogs for batch operations.
New Website
We’ve launched a new website that integrates the documentation and API references into a single experience. All pages are now hosted at the new docs section, with cross-links between features, API references, and the extended-features driver library. The same content, easier to navigate, with proper search.
Try it now
TinyCLR v3 is feature-complete and bench-tested — ready to use today. Some documentation pages are still being polished as we finish migrating content from the old site, but the firmware, libraries, and tools are all available.
Get started:
If you run into anything — documentation gaps, edge cases, or unexpected behavior — reach out through our forums or support. We’re actively monitoring as v3 hits real-world projects.
We can’t wait to see what you’ll build with TinyCLR v3.
Can we add a few more features? :nerd_face: What is your favorite new feature? I love seeing RLP is back!
I like the fact you can run TinyCLR on the Desktop before even touching the hardware. This opens up more options for team development and code testing.
Oh yeah, that is pretty sweet. But of course this is for non-hardware things, like file system and networking, and the core features as well.
Non-blocking sockets, Async/await, multi-network, RLP…. so many new toys to play with!
USB Hub support, one step closer to USB Cellular modems. :wink:
I’ve requested this many times. USB support for SERIAL ports. :laughing:
PS. I am just about to port my current home project to 3.0, a Nixie clock with Web interface for setup.
There is an issue when trying to add the online and offline WINC15x0 library.
Could not find a part of the path ‘C:\Users\DaveMcLaughlin\OneDrive\HomeFiles\OneDrive\Documents\VSSource\Visual Studio 2022\TinyCLRNixieClock\packages\GHIElectronics.TinyCLR.Drivers.Microchip.Winc15x0.3.0.0.2000-prerelease\GHIElectronics.TinyCLR.Drivers.Microchip.Winc15x0.3.0.0.2000-prerelease.nupkg’.
There is no .nupkg file in the location shown.
I just tested it, and it exists in both the online and the ZIP file. Please try uninstalling and reinstalling it again. Alternatively, you can copy it from our ZIP file and place it into your special folder.
Hey, that path looks a bit odd to me:
"GHIElectronics.TinyCLR.Drivers.Microchip.Winc15x0.3.0.0.2000-prerelease\GHIElectronics.TinyCLR.Drivers.Microchip.Winc15x0.3.0.0.2000-prerelease.nupkg"
Did you create that folder manually? How do the paths for the other NuGet packages look?
Hi Dat,
The package for Network, for example, is in the same directory under the project folder.
TinyCLRNixieClock\packages\GHIElectronics.TinyCLR.Devices.Network.3.0.0.2000-prerelease
The one causing the error, WINC15x is located here.
NUGET fails to install it from both online and offline. I even deleted the folder in the projects package directory.
I have since manually copied the files and although I still get the error, it now builds and runs on the target.
Epicness. Can’t wait to try it out.
This looks great, I can’t wait to clear my current backlog and give it a try!
Quick question, spacewise how does it compare on output size and memory/heap usage?
We are currently pushing for space on the SC20260, and it wouldn’t take much to take us over the limit.
Mscorlib is larger with all the additions. But don’t you use external memory?
We are using Extend Heap.
We’ve run into the out-of-string-space message a few times, which is a badly worded way of saying metadata is too big for the compilation unit. After shrinking down our user text messages to the point of unintelligibility, we realize what the actual error is, and try and find enough related code to pull out into a separate library! :smiley:
Doesn’t this desktop mode also mean that TinyCLR 3.0 now makes the PocketBeagle 2 a realistic target? A high-speed, low-level OS that’s better than the public “Linux” variants? 2-second boot. Massive performance?
EDIT: lol Endpoint on the A53 cores and TinyCLR on the M4F core.
Oh that would be great
Since v3 is “largely backward compatible with v2”, are we able to start using it with existing projects with little risk (i.e. it will run existing code the same as v2 did, but new v3 features are where the risk would be), or should we wait until the packages are no longer marked “prerelease”? I have a project with shipping products and one still in development.
I would certainly use v3 today but not ship products with it. We have good feeling about its stability. It will not be long before it is production ready. I am guessing a few short weeks.
Marvellous! Long-awaited.
We have more plans for UI but we didn’t want to hold v3 release for that.
