Hello,
I built the firmware for CerbuinoBee, V1.0.0, and have run a HelloWorld test. Are the NuGet libraries going to work OK? I have just started looking at them and was wondering if anyone else had encountered problems?
Yes they will but you have to make sure that whatever you need it use is actually implemented properly on your board. The only complete port is the one for FEZ. You can use that as a reference.
Thanks Gus. I will proceed.
