I have question why TinyCLR work only on debug mode ?
if i’m not on debug mode it do not run or
is not used GHIElectronics.TinyCLR.Config.exe
application stand alone do not work - or i am wrong something !!!
Do you mean when you build the firmware or the managed application?
managed app work only on debug not on release
if i deploy blink not work (do not start)
if i debug blink it work it start
How can see try this on our end?
very simple
create an blink an run on debug mode
if blink this is ok(this work on my side)
close visual studio,
remove power from board,
plug power on board (it need to start by default but there nothing happen - blink need to work too also without visual studio )
if i connect Ghielectronics.Tinyclr.config.exe it work in same way as debug (if i disconect it do not work)
tested Electron with G30 source.(latest dev branch)
The dev branch is really unstable right now, though we will make a note to take a look into this. Unfortunately we don’t have a fix off hand. Working with the master branch is the best bet.
