When Gus introduced TinyCLR OS, he says “TinyCLR OS has a similar API to the Windows 10 IoT Core Extensions API. For example, controlling a pin on a Raspberry PI running Windows 10 is very similar to how pins are now controlled on a FEZ Panda III”. It’s true
private GpioController _gpio;
private GpioPin _FezHatLedR;
private void Page_Loaded(object sender, RoutedEventArgs e) { _gpio = GpioController.GetDefault(); _FezHatLedR = _gpio.OpenPin(24); _FezHatLedR.SetDriveMode(GpioPinDriveMode.Output); _FezHatLedR.Write(GpioPinValue.Low); }
private void OnBTN_Click(object sender, RoutedEventArgs e) { _FezHatLedR.Write(GpioPinValue.High); }
private void OffBTN_Click(object sender, RoutedEventArgs e) { _FezHatLedR.Write(GpioPinValue.Low); }
