Pulled the module off my board and put it back on the dev board. Rebuilt my network only test to ensure it wasnt something strange with the new vsix. Reran and still cannot get it to connect with a static IP using the same exact settings and network infrastructure as the G400D version. Here is the code:
Program.cs
using System.Collections;
using System.Diagnostics;
using System.Text;
namespace NetworkTest2_1Prev4
public delegate void DataReceivedEventHandler(object sender, DataReceivedEventArgs e);
public delegate void ConnectionLostEventHandler(object sender);
class Program
//Network channel
public NetworkInterface Host;
//Threads
Thread ServerThread;
static void Main()
Program myApplication = new Program();
myApplication.initialize();
void initialize()
CreateNetworkInterface();
private void CreateNetworkInterface()
Host = new NetworkInterface(64010);
ServerThread = new Thread(() => Host.StartServer());
ServerThread.Priority = ThreadPriority.Highest;
ServerThread.Start();
Host.DataReceived += Host_DataReceived;
private void Host_DataReceived(object sender, DataReceivedEventArgs e)
Debug.WriteLine(e.Data);
NetworkInterface.cs
using GHIElectronics.TinyCLR.Devices.Network;
using System.Net;
using System.Net.Sockets;
using System.Text;
public class NetworkInterface : IDisposable
string resend = "";
static Socket serverSocket;
static Socket clientSocket;
static EndPoint ep;
//EthernetENC28J60 ethernet;
public bool IsConnected = false;
public event DataReceivedEventHandler DataReceived;
public event ConnectionLostEventHandler ConnectionLost;
public NetworkStream ns;
bool IsOpen = false;
private ManualResetEvent waitForCommandEvent;
private byte[] buffer;
private string carryOver;
private DateTime lastRead;
private DateTime lastWrite;
private Thread processingThread;
private ManualResetEvent networkRefreshEvent;
const int RESET = SC20260.GpioPin.PG3;
const string EMAC_API_NAME = "GHIElectronics.TinyCLR.NativeApis.STM32H7.EthernetEmacController\\0";
static bool phyReady = false;
public static bool linkReady = false;
public Queue CommandQueue { get; set; }
public static byte dash = 45;
public static byte LF = 10;
public static byte CR = 13;
public static byte space = 32;
private int port;
private readonly object locker;
private string resendInfo = "";
private int resendCount = 0;
public NetworkInterface(int port)
locker = new object();
CommandQueue = new Queue();
this.port = port;
waitForCommandEvent = new ManualResetEvent(false);
networkRefreshEvent = new ManualResetEvent(true);
buffer = new byte[100];
// Do external Phy reset
var gpioController = GpioController.GetDefault();
var resetPin = gpioController.OpenPin(RESET);
resetPin.SetDriveMode(GpioPinDriveMode.Output);
resetPin.Write(GpioPinValue.Low);
Thread.Sleep(100);
resetPin.Write(GpioPinValue.High);
Thread.Sleep(100);
var networkController = NetworkController.FromName(EMAC_API_NAME);
EthernetNetworkInterfaceSettings networkInterfaceSetting = new EthernetNetworkInterfaceSettings();
BuiltInNetworkCommunicationInterfaceSettings networkCommunicationInterfaceSettings = new BuiltInNetworkCommunicationInterfaceSettings();
networkInterfaceSetting.Address = new IPAddress(new byte[] { 172, 16, 0, 106 });
networkInterfaceSetting.SubnetMask = new IPAddress(new byte[] { 255, 255, 255, 0 });
networkInterfaceSetting.GatewayAddress = new IPAddress(new byte[] { 172, 16, 0, 255 });
networkInterfaceSetting.DnsAddresses = new IPAddress[] { new IPAddress(new byte[] { 8, 8, 8, 8 }), new IPAddress(new byte[] { 8, 8, 4, 4 }) };
networkInterfaceSetting.TlsEntropy = new byte[] { 0, 1, 2, 3 };
networkInterfaceSetting.MacAddress = new byte[] { 0x70, 0xB3, 0xD5, 0xFA, 0xC0, 0x0F };
//networkInterfaceSetting.MacAddress = new byte[] { 0x00, 0x4, 0x00, 0x00, 0x00, 0x00 };
networkInterfaceSetting.DhcpEnable = false;
networkInterfaceSetting.DynamicDnsEnable = false;
//networkInterfaceSetting.Address = new IPAddress(config.network.IPAddress);
//networkInterfaceSetting.SubnetMask = new IPAddress(config.network.SubnetMask);
//networkInterfaceSetting.GatewayAddress = new IPAddress(config.network.DefaultGateway);
//networkInterfaceSetting.DnsAddresses = new IPAddress[] { new IPAddress(config.network.DNSAddress1), new IPAddress(config.network.DNSAddress2) };
//networkInterfaceSetting.TlsEntropy = config.network.TlsEntropy;
//networkInterfaceSetting.MacAddress = config.network.MACAddress;
//networkInterfaceSetting.DhcpEnable = config.network.IsDHCP;
//networkInterfaceSetting.DynamicDnsEnable = config.network.IsDynamicDNS;
networkController.SetInterfaceSettings(networkInterfaceSetting);
networkController.SetCommunicationInterfaceSettings(networkCommunicationInterfaceSettings);
networkController.SetAsDefaultController();
networkController.NetworkAddressChanged += NetworkController_NetworkAddressChanged;
networkController.NetworkLinkConnectedChanged += NetworkController_NetworkLinkConnectedChanged;
networkController.Enable();
while (linkReady == false) ;
System.Diagnostics.Debug.WriteLine("Network is ready to use");
private static void NetworkController_NetworkLinkConnectedChanged(NetworkController sender, NetworkLinkConnectedChangedEventArgs e)
phyReady = e.Connected;
System.Diagnostics.Debug.WriteLine("Phy status " + phyReady);
private static void NetworkController_NetworkAddressChanged(NetworkController sender, NetworkAddressChangedEventArgs e)
var ipProperties = sender.GetIPProperties();
var address = ipProperties.Address.GetAddressBytes();
var subnet = ipProperties.SubnetMask.GetAddressBytes();
var gw = ipProperties.GatewayAddress.GetAddressBytes();
var interfaceProperties = sender.GetInterfaceProperties();
System.Diagnostics.Debug.WriteLine("Mac: " + interfaceProperties.MacAddress[0].ToString("x") + ":" + interfaceProperties.MacAddress[1].ToString("x") + ":" + interfaceProperties.MacAddress[2].ToString("x") + ":" + interfaceProperties.MacAddress[3].ToString("x") + ":" + interfaceProperties.MacAddress[4].ToString("x") + ":" + interfaceProperties.MacAddress[5].ToString("x"));
System.Diagnostics.Debug.WriteLine("ip address :" + address[0] + "." + address[1] + "." + address[2] + "." + address[3]);
System.Diagnostics.Debug.WriteLine("subnetmask :" + subnet[0] + "." + subnet[1] + "." + subnet[2] + "." + subnet[3]);
System.Diagnostics.Debug.WriteLine("gate way :" + gw[0] + "." + gw[1] + "." + gw[2] + "." + gw[3]);
var dnsCount = ipProperties.DnsAddresses.Length;
for (int i = 0; i < dnsCount; i++)
var dns = ipProperties.DnsAddresses[i].GetAddressBytes();
System.Diagnostics.Debug.WriteLine("dns[" + i + "] :" + dns[0] + "." + dns[1] + "." + dns[2] + "." + dns[3]);
linkReady = address[0] != 0 ? true : false;
public void StartServer()
try
//IsOpen = false;
//create server socket
serverSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
serverSocket.SetSocketOption(SocketOptionLevel.Tcp, SocketOptionName.NoDelay, true);
serverSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
//serverSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.DontLinger, true);
serverSocket.SetSocketOption(SocketOptionLevel.Tcp, SocketOptionName.Debug, true);
//bind socket to all available endpoints (should only be the ethernet on the board)
ep = new IPEndPoint(IPAddress.Any, port);
serverSocket.Bind(ep);
//start listening for connections
Debug.WriteLine("Listening for connections on port " + port.ToString());
serverSocket.Listen(5);
clientSocket = serverSocket.Accept();
clientSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
//clientSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.DontLinger, true);
clientSocket.SetSocketOption(SocketOptionLevel.Tcp, SocketOptionName.NoDelay, true);
IsOpen = true;
IsConnected = true;
if (resend != "")
Send(resend);
ns = new NetworkStream(clientSocket);
ns.ReadTimeout = Timeout.Infinite;
//set writeTimeout to 2 sec
ns.WriteTimeout = 2000;
Debug.WriteLine(DateTime.Now.ToString() + " Accepted New Connection");
if (processingThread == null)
StartProcessingResponses();
else if (!processingThread.IsAlive)
catch (Exception ex)
Debug.WriteLine("Unable to start server!");
Debug.WriteLine(ex.Message);
serverSocket.Close();
serverSocket = null;
private void StartProcessingResponses()
processingThread = new Thread(() =>
//ensure the network is up
while (IsOpen)
ArrayList commands = null;
try
commands = ReadCommand();
catch (Exception e)
IsOpen = false;
Debug.WriteLine(e.Message);
//check to make sure there is an ID, otherwise ignore
if (commands == null)
continue;
// put the repsonse into the dictionary for the corresponding command
//Debug.Print("Got Command: " + command);
foreach (string command in commands)
DataReceived(this, new DataReceivedEventArgs(command));
//CommandQueue.Enqueue(command);
//Debug.Print(command);
processingThread.Start();
private ArrayList ReadCommand()
//Debugger.Launch();
//clear the buffer byte[]
Array.Clear(buffer, 0, buffer.Length);
ArrayList response = new ArrayList();
int readAll = 0;
int read;
networkRefreshEvent.WaitOne();
//read data from the network stream byte by byte
try
while (ns.DataAvailable)
lastRead = DateTime.Now;
read = ns.Read(buffer, readAll, buffer.Length - readAll);
readAll += read;
//ReadBytes = readAll;
string rawMessage = new string(Encoding.UTF8.GetChars(buffer));
//string rawMessage = carryOver + new string(Encoding.UTF8.GetChars(buffer));
//Debug.Print("Raw Read = " + rawMessage);
response = processData(buffer);
return response;
// indexOfEnd = rawMessage.IndexOf("\r\n", 0) + 2;
// if (rawMessage.Length > indexOfEnd)
// var stringArray = rawMessage.Split('\n');
// for (int i = 0; i < stringArray.Length - 1; i++)
// if(stringArray[i].IndexOf('-') != -1)
// response.Add(stringArray[i] + '\n');
// carryOver = "";
// else
// carryOver = stringArray[i];
// break;
// else
// if(rawMessage.IndexOf("\r\n")>2)
// if (rawMessage.IndexOf('-') != -1)
// response.Add(new string(Encoding.UTF8.GetChars(buffer)) + '\n');
// carryOver = "";
// break;
// else
// carryOver = rawMessage;
// else
Thread.Sleep(20);
return response;
Debug.WriteLine("Error: " + ex.Message);
return response;
private ArrayList processData(byte[] buffer)
string commandString = carryOver + new string(Encoding.UTF8.GetChars(buffer));
int startChar = commandString.IndexOf('-');
int endChar = commandString.IndexOf("\r\n");
if (startChar != -1 && endChar != -1)
//make sure framing chars are in the right order
if (startChar < endChar)
//string split to see if multiple commands exist
var commandStrings = commandString.Split('\n');
foreach (string com in commandStrings)
//if com has remaining framing chars, add the response
if (com.IndexOf('-') != -1 && com.IndexOf('\r') != -1 && com.IndexOf('-') < com.IndexOf('\r'))
response.Add(com + "\n");
//Debug.Print("adding " + com);
carryOver = "";
// if the com doesn't have the framing chars or they are in the wrong order, add the data to carryover
carryOver = com;
carryOver = commandString;
else if (startChar != -1 && endChar == -1)
else if (startChar == -1 && endChar != -1)
Debug.WriteLine("Error occured in parsing");
return response;
//wrapper for socket send
public void Send(string sendInfo)
lock (locker)
byte[] message = UTF8Encoding.UTF8.GetBytes(sendInfo);
byte[] resendMessage = UTF8Encoding.UTF8.GetBytes(resendInfo);
try
lastWrite = DateTime.Now;
//if there is a resend message, send it first
if (string.Compare(resendInfo, "") != 0)
ns.Write(resendMessage, 0, resendMessage.Length);
//clear resend info here so we know if this send went through
resendInfo = "";
//clear the count
resendCount = 0;
Debug.WriteLine("Finished resend");
ns.Write(message, 0, message.Length);
//ns.Flush();
//Thread.Sleep(20);
Debug.WriteLine("Round trip time: " + (lastWrite - lastRead));
if ((lastWrite - lastRead) > new TimeSpan(0, 0, 1))
Debug.WriteLine("******************************************************************************************************");
catch
//if we timeout on a send, remember what was trying to be sent and cache it.
//Increment the counter. If we get to 5, do something drastic.
//set resend;
resendInfo = sendInfo;
//increment counter
resendCount += 1;
//set resend info so when we reconnect, we send again
Debug.WriteLine("setting resend to: " + resendInfo);
private void OnDataReceived(DataReceivedEventArgs e)
if (DataReceived != null)
DataReceived(this, e);
public void Dispose()
clientSocket.Close();
DataReceivedEventArgs.cs
public class DataReceivedEventArgs : EventArgs
//public EndPoint LocalEndPoint { get; private set; }
//public EndPoint RemoteEndPoint { get; private set; }
//public byte[] Data { get; private set; }
public string Data { get; set; }
public bool Close { get; set; }
public byte[] ResponseData { get; set; }
//public DataReceivedEventArgs(EndPoint localEndPoint, EndPoint remoteEndPoint, byte[] data)
public DataReceivedEventArgs(string data)
//LocalEndPoint = localEndPoint;
//RemoteEndPoint = remoteEndPoint;
if (data != null)
//Data = new byte[data.Length];
Data = data;
//data.CopyTo(Data, 0);
