As a gift for the holidays, we wanted to share the current roadmap for TinyCLR OS. Of course, this is all subject to change and not a promise, but it’s a good outline of our current goal for a stable, production-ready 1.0 release. Nor does it include the many small improvements and features that will make it in.
v0.7.0 in January
Adding CAN to several ports and the library
Improving usage of interops
More complete pins library
v0.8.0 in February
A Cortex-M7 build of the core library
Low-level STMicroelectronics WiFi driver
FEZ Hydra firmware
v0.9.0 in March
A .NET sockets and HTTP library for any interface (including ST’s WiFi)
Native driver for SPI displays
Additional ports for other third-party devices
v1.0.0 Release Candidate in April
No new features planned for this release. Instead it’ll be a lot of final polish, bug fixing, documentation updates, and publishing in the online galleries. If all goes well, we’re aiming for a final release in May.
While we will continue to support and fix bugs in 1.0, we’re not done there! High on our list for 2.0 are several important features like file system, better and secure networking, in field update, more graphics, and USB host and client. We hope to get as many of these out as we can by the end of 2018.
just do not say v1.0 RC was on APRIL 1st (hope networking even partially will be included on this relese for IoT with ENC28j60 or any Wiz5100,Wiz5200,Wiz 5500…)
Azure is one of the things we test and require before anything else. We have actually made changes to grantee best experience with azure and other high end cloud services.
If you use a device with built on stack, like WiFi and cell module then it is not too far out as listed in the roadmap. If you are taking about the built on stack for Ethernet use then yes it is a year out. Netmf would be the way to go for now.
Note that this is the roadmap as if today and it will be updated monthly with every release.
unfortunately not possible due to existing issues like memory leak and missing tls support so based on your roadmap it looks like TinyCLR OS starts to be interesting by the end of 2018
This is such a small features that we can add whenever we have extra free time. You can also use directly or implement yourself. It shouldn’t be more than a day off work. Just giving options
