Hi Guys,
I’ve updated Henrik Hagardzons (@Honken) NetMF EEPROM code to work with TinyCLR and I thought id share it with you as i’ve seen a few people asking for it ( It’s only a first cut so there might be some bugs! )
Main class:
using System.Runtime.InteropServices;
namespace Monoculture.TinyCLR.Drivers.G120EEPROM
public class G120EEPROMDriver
public const uint PageSize = 64;
private const int CMD_8BITS_READ = 0;
private const int CMD_8BITS_WRITE = 3;
private const int CMD_RDPREFETCH = 1 << 3;
private const int RDWR_CLR_ST = 1 << 26;
private const int INT_ENDOFPROG = 1 << 28;
private const int CMD_ERASE_PRG_PAGE = 6;
private readonly IntPtr EECMD = new IntPtr(0x00200080);
private readonly IntPtr EEADDR = new IntPtr(0x00200084);
private readonly IntPtr EEWDATA = new IntPtr(0x00200088);
private readonly IntPtr EERDATA = new IntPtr(0x0020008C);
private readonly IntPtr EEWSTATE = new IntPtr(0x00200090);
private readonly IntPtr EECLKDIV = new IntPtr(0x00200094);
private readonly IntPtr PWRDWN = new IntPtr(0x00200098);
private readonly IntPtr STAT = new IntPtr(0x00200FE0);
private readonly IntPtr STATCLR = new IntPtr(0x00200FE8);
public G120EEPROMDriver(uint speed = 120000000)
Marshal.WriteInt32(PWRDWN, 0);
Marshal.WriteInt32(EECLKDIV, (int)speed / 375000 - 1);
var phase1 = (byte)(speed / 1000000 * 15 / 1000 + 1);
var phase2 = (byte)(speed / 1000000 * 55 / 1000 + 1);
var phase3 = (byte)(speed / 1000000 * 35 / 1000 + 1);
var states = phase1 | phase2 << 8 | phase3 << 16;
Marshal.WriteInt32(EEWSTATE, states);
/// <summary>
/// Reads data from the internal EEPROM
/// </summary>
/// <param name="page">0-62</param>
/// <param name="address">0-63</param>
/// <param name="size">Size of data</param>
/// <returns>Data read from EEPROM</returns>
public byte[] Read(uint page, uint address, uint size)
var readBuffer = new byte[size];
// Clear read/write status
Marshal.WriteInt32(STATCLR, RDWR_CLR_ST);
// Write address register
Marshal.WriteInt32(EEADDR, (int)((page & 0x3F) << 6 | address & 0x3F));
// Set command to read 8 bits + prefetch next address
Marshal.WriteInt32(EECMD, CMD_8BITS_READ | CMD_RDPREFETCH);
// Loop through buffer.
for (var i = 0; i < readBuffer.Length; i++)
readBuffer[i] = Marshal.ReadByte(EERDATA);
WaitForInterruptStatus(RDWR_CLR_ST);
address++;
if (address < PageSize) continue;
page++;
address = 0;
return readBuffer;
/// <summary>
/// Writes data to the internal EEPROM
/// </summary>
/// <param name="data">Data to write</param>
public void Write(uint page, uint address, byte[] data)
// set address
// set write 8-bit
Marshal.WriteInt32(EECMD, CMD_8BITS_WRITE);
for (var i = 0; i < data.Length; i++)
// write 8 bits to page register
Marshal.WriteInt32(EEWDATA, data[i]);
address++;
// clear page erase status
Marshal.WriteInt32(STATCLR, CMD_ERASE_PRG_PAGE);
// set address to base of current page
Marshal.WriteInt32(EEADDR, (int)((page & 0x3F) << 6 | 0 & 0x3F));
// Program current page
Marshal.WriteInt32(EECMD, CMD_ERASE_PRG_PAGE);
// Wait for operation to complete
WaitForInterruptStatus(INT_ENDOFPROG);
page++;
address = 0;
// set write 8-bit
private void WaitForInterruptStatus(int mask)
var status = Marshal.ReadInt32(STAT);
if ((status & mask) == mask)
break;
Usage:
namespace Monoculture.TinyCLR.Drivers.G120EEPROM.Demo
class Program
public class Settings
public int Property1 { get; set; }
public int Property2 { get; set; }
static void Main()
var eeprom = new G120EEPROMDriver();
var settings = new Settings();
LoadSettings(eeprom, settings);
settings.Property1 = 100;
settings.Property2 = 200;
SaveSettings(eeprom, settings);
private static void LoadSettings(G120EEPROMDriver eeprom, Settings settings)
var buffer = eeprom.Read(0, 0, G120EEPROMDriver.PageSize);
settings.Property1 = BitConverter.ToInt32(buffer, 0);
settings.Property2 = BitConverter.ToInt32(buffer, 4);
private static void SaveSettings(G120EEPROMDriver eeprom, Settings settings)
var buffer = new byte[G120EEPROMDriver.PageSize];
BitConverter.GetBytes(settings.Property1).CopyTo(buffer, 0);
BitConverter.GetBytes(settings.Property2).CopyTo(buffer, 4);
eeprom.Write(0, 0, buffer);
