The font converter will not install on my windows 10 pro.
Using TinyCLR%20OS%20Font%20Converter%20v1.0.0-preview2.exe
Not a issue for me but I would like to use it.
Thanks!
Thanks!
Nothing to install as it is a command line tool.
Or better yet… .NET Micro Framework
Did not know that it was a command line tool.
However, run the exe and it just flashes on the desktop and then goes away.
Thank you and scardinale for the response.
I have the same issue.
Should this be run in some other version of windows?
did you open a command line prompt, navigate to the folder where either your font is or the app is, and run it?
Thanks so much this worked!!!
I hope GHI updates their official documentation to show this to others.
