I am using an UC5550 with a development board. While trying the tutorial code for the FileStystem tutorial, I get the following errors in my Microsoft Visual Studio:
Yes I did install the NuGet packages that are included in the tutorial, these are GHIElectronics.TinyCLR.Devices.Storage and GHIElectronics.TinyCLR.IO and I tried to reinstall those several times with no positive effects unfortunately.
I’m wondering if the namespace in your code matches the namespace of your project.
When you cut and paste the code from tutorials, make sure the namespace statement (“namespace FileSystem” in this case) is changed to match the name you used when creating your project. Or, create a new project named “FileSystem” and use the code as is.
