TinyCLR Error
I have downloaded the Glide source and changed the framework to 4.2. When I go to build the solution I get the error message shown in the image. Everything seems to be in line but it keeps failing. Looked for a bit on the forum and found a couple similar problems but couldn’t find the answer yet.
Are you trying to “run” just the Glide project?
It is a library, you supposed to use it in your actual application.
