I have updated a working application to 1.0.0-preview3.
Using a UCM Dev Board Rev E with a UC5550 with WiFi
Using a UD700 Rev A display
GHIElectronics.TinyCLR.Devices.Display.1.0.0-preview3
The Display no longer works. Remains dark.
Display worked when using 1.0.0-preview2
Any suggestions?
There are 2 things updated on graphic driver.
- The backlight pin is set by user manually. Meaning you have to pull this pin to high.
- You have to call controller.Enable() after Set Configuration.
controller.Enable() Is used.
Now off to find that backlight pin…
I am not able to find the pin reference to the backlight pin.
Could you please provide. I have checked your Pin Assignments reference.
Thanks for the quick reply!
Looking at the display schematic, the backlight pin is right next to 5v http://files.ghielectronics.com/downloads/Schematics/Systems/UD435%20Rev%20A%20Schematic.pdf
I do not have a board handy but take a look at the dev board please and see what pin that is.
For quickly
UC5550 on Dev:
const int BACKLIGHT = 3 * 16 + 7; // PD7
FEZ Cobra II / G120E Dev:
const int BACKLIGHT = 2 * 32 + 21; // P2_21
G400D using UCM Dev board
const int BACKLIGHT = 3 * 32 + 14; // PD14 - UCM
These connect to GPIO A on UCM
GPIO B for interrupt, if I remember correctly.
Thanks for the Info!
Got it working using:
private static GpioPin backlight_GPIOA;
//LCD Backlight - High = ON
backlight_GPIOA = GpioController.GetDefault().OpenPin(UC5550.GpioPin.PD7);
backlight_GPIOA.SetDriveMode(GpioPinDriveMode.Output);
backlight_GPIOA.Write(GpioPinValue.High);
