TinyCLR Config crashes with SCM20260
TinyCLR version is 2.4.0.1000
When I try to do a firmware update, it gives the following error message
Can’t connect to the device. Refresh port and connect again.
When I do try to reconnect it is still in loader mode and when I select the port, it crashes. The event viewer shows this in one of the logs:
Sig[0].Name=Problem Signature 01
Sig[0].Value=GHIElectronics.TinyCLR.Config
Sig[1].Name=Problem Signature 02
Sig[1].Value=2.4.0.1000
Sig[2].Name=Problem Signature 03
Sig[2].Value=69b8594d
Sig[3].Name=Problem Signature 04
Sig[3].Value=GHIElectronics.TinyCLR.Config
Sig[4].Name=Problem Signature 05
Sig[4].Value=2.4.0.1000
Sig[5].Name=Problem Signature 06
Sig[5].Value=69b8594d
Sig[6].Name=Problem Signature 07
Sig[6].Value=101
Sig[7].Name=Problem Signature 08
Sig[7].Value=1dd
Sig[8].Name=Problem Signature 09
Sig[8].Value=System.NullReferenceException
I am unable to update the firmware.
I can’t even connect and erase all.
Somehow your PC has a USB port conflict. In Device Manager, uninstall the COM port driver and let it be automatically recognized again. If that doesn’t help, try using a different computer to check.
