TinyCLR 2.0 System.Drawing.Font Error
I ran this simple code on a FEZ Feather running TinyCLR 2.0.0 and I am getting an error calling the DrawString method.
Error:
An unhandled exception of type ‘System.ArgumentException’ occurred in GHIElectronics.TinyCLR.Drawing.dll
static void Main()
            var controller = I2cController.FromName(SC20100.I2cBus.I2c1);
            var i2cDevice = controller.GetDevice(SSD1306Controller.GetConnectionSettings());
            SSD1306Controller ssd1306Controller = new SSD1306Controller(i2cDevice);
            var screen = Graphics.FromImage(new Bitmap(128, 32));
            var font = new Font("GHIMono8x5", 8);
            var brush =  new SolidBrush(System.Drawing.Color.White);
            Graphics.OnFlushEvent += (s, d) => {
                ssd1306Controller.DrawBuffer(d);
            screen.FillRectangle(brush, 0, 0, 30, 32); //Works
            screen.Flush();
            screen.DrawEllipse(new System.Drawing.Pen(System.Drawing.Color.White), 32, 0, 30, 30); //Works
            screen.Flush();
            Thread.Sleep(1000);
            screen.DrawString("Welcome", font, brush, 34, 0); //Throws an error
            screen.Flush();
Doing some investigation, I noticed that the height property on the Font class is throwing an error.
Is this the proper way to instantiate the font class?
that font is no longer supported.
Thanks Dat.
So is there another built-in font or do I have to convert a font using the font conversion tool?
you need to convert.
This is no longer supported. Where did you find this code?
Thanks again.
Hey Gus,
Built-in fonts
When using systems with managed SPI display drivers, the font support is handled though an internal built-in font. This is done to reduce memory requirements.
var teal = new SolidBrush(Color.Teal);
screen.DrawString("Hello World!", font, teal, 40, 10);
screen.Flush();
Thanks,
Added an issue :))
https://github.com/ghi-electronics/TinyCLR-Devices/issues/827
