Yep that is my problem there. looks like i’ll be able to get a workable solution out of that info. probably after a lot of reading, trial and error.
In the long run I need to make an object lock that is required for the chip select pin to operate. To make my spi bus thread safe for the future. Does that sound possible? or are the cs pins switched in the native code. I’ve got 3 different chip’s connected to it. So I’ve got a feeling this might come around again.
