I feel like such a forum leach lately. It annoys me when people ask for help building a solution with out having a crack first them selves. They are usually rewarded with sarcasm or no reply’s. Please believe me when I say I’ve tried with this problem for days with no luck, I’m just out of my depth here on this project. I believe the answer lays somewhere in either using the monitor class or interlocked. Connected to my project [G120], on SPI2 is an 74hc595 driving a 4X20 Character LCD. Also using SPI2 is an MCP3208 ADC. Both are set up using the MultiSPI class from Stefan’s awesome tool box.
* Copyright 2011-2014 Stefan Thoolen (http://www.netmftoolbox.com/)
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
namespace G120.SAL.ToolBox
/// <summary>
/// SPI Helper to make it easier to use multiple SPI-devices on one SPI-bus
/// </summary>
public class MultiSPI
/// <summary>Reference to the SPI Device. All MultiSPI devices use the same SPI class from the NETMF, so this reference is static</summary>
private static SPI _SPIDevice;
/// <summary>SPI Configuration. Different for each device, so not a static reference</summary>
private SPI.Configuration _Configuration;
/// <summary>There is a software ChipSelect feature because of a bug. True when enabled</summary>
/// <remarks>see http://netduino.codeplex.com/workitem/3 for more details about the bug.</remarks>
private bool _Use_SoftwareCS;
/// <summary>Reference to the latch-pin when using software chip-select</summary>
private OutputPort _SoftwareCS;
/// <summary>Active state when using software chip-select</summary>
private bool _SoftwareCS_ActiveState;
/// <summary>Returns the SPI Configuration</summary>
public SPI.Configuration Config { get { return this._Configuration; } }
/// <summary>
/// Initializes a new SPI device
/// </summary>
/// <param name="config">The SPI-module configuration</param>
public MultiSPI(SPI.Configuration config)
// The timing of the Netduino pin 4, Netduino Plus pin 4 and Netduino Mini pin 13 have a small bug, probably in the IC or NETMF itself.
// They all refer to the same pin ID on the AT91SAM7X512: (int)12
// - SecretLabs.NETMF.Hardware.Netduino.Pins.GPIO_PIN_D4
// - SecretLabs.NETMF.Hardware.NetduinoPlus.Pins.GPIO_PIN_D4
// - SecretLabs.NETMF.Hardware.NetduinoMini.Pins.GPIO_PIN_13
// To work around this problem we use a software chip select. A bit slower, but it works.
// We will include this work-around until the actual bug is fixed.
bool SoftwareChipSelect = false;
//if ((int)config.ChipSelect_Port == 12 && (
// Tools.HardwareProvider == "Netduino" || Tools.HardwareProvider == "NetduinoMini" || Tools.HardwareProvider == "NetduinoPlus"
// Debug.Print("MultiSPI: Software ChipSelect enabled to prevent timing issues");
// Debug.Print("MultiSPI: See http://netduino.codeplex.com/workitem/3 for more");
// SoftwareChipSelect = true;
// Sets the configuration in a local value
this._Configuration = config;
// When we use a software chipset we need to record some more details
if (SoftwareChipSelect)
this._SoftwareCS = new OutputPort(config.ChipSelect_Port, !config.ChipSelect_ActiveState);
this._SoftwareCS_ActiveState = config.ChipSelect_ActiveState;
this._Use_SoftwareCS = true;
// Copies the Configuration, but without Chip Select pin
this._Configuration = new SPI.Configuration(
Cpu.Pin.GPIO_NONE,
_Configuration.BusyPin_ActiveState,
_Configuration.ChipSelect_SetupTime,
_Configuration.ChipSelect_HoldTime,
_Configuration.Clock_IdleState,
_Configuration.Clock_Edge,
_Configuration.Clock_RateKHz,
_Configuration.SPI_mod,
_Configuration.BusyPin,
// If no SPI Device exists yet, we create it's first instance
if (_SPIDevice == null)
// Creates the SPI Device
_SPIDevice = new SPI(this._Configuration);
/// <summary>
/// The 8-bit bytes to write to the SPI-buffer
/// </summary>
/// <param name="WriteBuffer">An array of 8-bit bytes</param>
public void Write(byte[] WriteBuffer)
if (this._Use_SoftwareCS) this._SoftwareCS.Write(this._SoftwareCS_ActiveState);
_SPIDevice.Config = this._Configuration;
_SPIDevice.Write(WriteBuffer);
if (this._Use_SoftwareCS) this._SoftwareCS.Write(!this._SoftwareCS_ActiveState);
/// <summary>
/// The 16-bit bytes to write to the SPI-buffer
/// </summary>
/// <param name="WriteBuffer">An array of 16-bit bytes</param>
public void Write(ushort[] WriteBuffer)
/// <summary>
/// Reads 8-bit bytes
/// </summary>
/// <param name="ReadBuffer">An array with 8-bit bytes to read</param>
public void Read(byte[] ReadBuffer)
_SPIDevice.WriteRead(ReadBuffer, ReadBuffer); // First parameter is actually a WriteBuffer
/// <summary>
/// Reads 16-bit bytes
/// </summary>
/// <param name="ReadBuffer">An array with 16-bit bytes to read</param>
public void Read(ushort[] ReadBuffer)
/// <summary>
/// Writes an array of 8-bit bytes to the interface, and reads an array of 8-bit bytes from the interface.
/// </summary>
/// <param name="WriteBuffer">An array with 8-bit bytes to write</param>
public void WriteRead(byte[] WriteBuffer, byte[] ReadBuffer)
_SPIDevice.WriteRead(WriteBuffer, ReadBuffer);
/// <summary>
/// Writes an array of 16-bit bytes to the interface, and reads an array of 16-bit bytes from the interface.
/// </summary>
/// <param name="WriteBuffer">An array with 16-bit bytes to write</param>
public void WriteRead(ushort[] WriteBuffer, ushort[] ReadBuffer)
/// <summary>
/// Writes an array of 8-bit bytes to the interface, and reads an array of 8-bit bytes from the interface into a specified location in the read buffer.
/// </summary>
/// <param name="StartReadOffset">The offset in time, measured in transacted elements from writeBuffer, when to start reading back data into readBuffer</param>
public void WriteRead(byte[] WriteBuffer, byte[] ReadBuffer, int StartReadOffset)
_SPIDevice.WriteRead(WriteBuffer, ReadBuffer, StartReadOffset);
/// <summary>
/// Writes an array of 16-bit bytes to the interface, and reads an array of 16-bit bytes from the interface into a specified location in the read buffer.
/// </summary>
public void WriteRead(ushort[] WriteBuffer, ushort[] ReadBuffer, int StartReadOffset)
/// <summary>
/// </summary>
/// <param name="WriteOffset">The offset in writeBuffer to start write data from</param>
/// <param name="WriteCount">The number of elements in writeBuffer to write</param>
/// <param name="ReadOffset">The offset in readBuffer to start read data from</param>
/// <param name="ReadCount">The number of elements in readBuffer to fill</param>
public void WriteRead(byte[] WriteBuffer, int WriteOffset, int WriteCount, byte[] ReadBuffer, int ReadOffset, int ReadCount, int StartReadOffset)
_SPIDevice.WriteRead(WriteBuffer, WriteOffset, WriteCount, ReadBuffer, ReadOffset, ReadCount, StartReadOffset);
/// <summary>
/// </summary>
public void WriteRead(ushort[] WriteBuffer, int WriteOffset, int WriteCount, ushort[] ReadBuffer, int ReadOffset, int ReadCount, int StartReadOffset)
As long as I don’t try to read the ADC whilst updating the display, all is well. But that is what I need to do. I need thread 1 to be updating the display, whilst thread 2 might need to scan the ADC. The fist thing I tried was having a public bool called “Is_Displaying”. I got the displaying thread to hold the bool until the display was updated and return it so the ADC thread could be run. This was a failure of course as it seemed like they could both change the bool at the same time? Then I used locking. Locking actually works to stop the collision of the threads on the spi bus, but it does not suit my project because it holds up thread2 which has other duties that need preforming.
easier solution;
If I could create a code that read the state of the lock, and skipped over trying to read the ADC in the case that the spi was in use. I could live with that. The ADC data wouldn’t be updated but would be a few ms old. that’s ok. It could be updated once the display update was complete.
harder but better solution;
I have quite a crowded little spi_bus going on here. would It be possible to add a priority number to the MultiSPI class? so that every device I added using the constructor[I think that’s the correct term]. I could add a number for a priority. Because the display should always wait for the ADC, even if it is halfway through updating?
If this is to much too ask over the forums but someone would like to offer their services for a small fee. Please PM me.
