Hello,
I have measured that System.Threading.Timer has a very strange scheduling behaviour on the G400.
Thread: 100% CPU toggling a GPIO (Blue trace). This lets us see when the scheduler runs, every 20ms (a gap appears)
I start 5 timers, each scheduled for 100ms period, i.e.
T = 100,100,100,100,100
When they fire, they toggle a GPIO one time (Magenta trace)
As expected, every 5 times the scheduler runs, it fires all five timers one after the other:
However, this is what happens if I reduce one timerâs period slightly, i.e.
T = 100,100,100,100,80
You can see that the timers are now scheduled exactly 1 timer per scheduling event:
I have tried with various combinations of timers and period, and have found that you CANNOT exceed 1 timer elapsing every 20ms, or your timing is hopelessly lost. In fact, there are events which are silently discarded.
E.g.:
T=40,40 works (0,2,0,2) and 40,20 does not. Should be 1,2,1,2 but is 1,1,1,1 (50% get lost!)
T=60,60,60 (0,0,3,0,0,3) works and 60,60,40 does not. Should be 0,1,2,1,0,3⌠but is 1,1,1,1
I donât understand this requirement, it seems really arbitrary that it is willing to fire more than one timer per scheduler event in some cases, but not in others.
I tried to find the limit, and found that you cannot increase the number of timers indefinitely - in fact 5 timers elapsing seems to be the maximum permitted per scheduling event.
If you try 10 timers (T=200,200,200,200,200) in fact you get 5 simultaneously, then 1 each for the next 5 scheduling events. This is even more bizarre than I might have expected (5 and then 5)
I feel pretty strongly that this is a bug and not a design feature. When I schedule things, I expect my framework to make a best effort to achieve it, instead of silently giving up my timing requirements and firing fewer events than I had requested.
Can I get some insight here please?
Thank you;
William
