I love the concept and the security. Has anyone tried to blink an LED? What are your thoughts so far?
Here is the blink LED demo that shipped with it…(Sorry no C# here!)
#include <errno.h>
#include <signal.h>
#include <stdbool.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
#include <unistd.h>
// applibs_versions.h defines the API struct versions to use for applibs APIs.
#include "applibs_versions.h"
#include "epoll_timerfd_utilities.h"
#include <applibs/gpio.h>
#include <applibs/log.h>
#include "mt3620_rdb.h"
// This sample C application for the MT3620 Reference Development Board (Azure Sphere)
// blinks an LED.
// The blink rate can be changed through a button press.
// It uses the API for the following Azure Sphere application libraries:
// - gpio (digital input for button)
// - log (messages shown in Visual Studio's Device Output window during debugging)
// File descriptors - initialized to invalid value
static int gpioButtonFd = -1;
static int gpioButtonTimerFd = -1;
static int gpioLedFd = -1;
static int gpioLedTimerFd = -1;
static int epollFd = -1;
// Button state variables
static GPIO_Value_Type buttonState = GPIO_Value_High;
static GPIO_Value_Type ledState = GPIO_Value_High;
// Blink interval variables
static const int numBlinkIntervals = 3;
static const struct timespec blinkIntervals[] = {{0, 125000000}, {0, 250000000}, {0, 500000000}};
static int blinkIntervalIndex = 0;
// Termination state
static volatile sig_atomic_t terminationRequired = false;
/// <summary>
/// Signal handler for termination requests. This handler must be async-signal-safe.
/// </summary>
static void TerminationHandler(int signalNumber)
// Don't use Log_Debug here, as it is not guaranteed to be async signal safe
terminationRequired = true;
/// <summary>
/// Handle LED timer event: blink LED.
/// </summary>
static void LedTimerEventHandler()
if (ConsumeTimerFdEvent(gpioLedTimerFd) != 0) {
return;
// The blink interval has elapsed, so toggle the LED state
// The LED is active-low so GPIO_Value_Low is on and GPIO_Value_High is off
ledState = (ledState == GPIO_Value_Low ? GPIO_Value_High : GPIO_Value_Low);
int result = GPIO_SetValue(gpioLedFd, ledState);
if (result != 0) {
Log_Debug("ERROR: Could not set LED output value: %s (%d).\n", strerror(errno), errno);
/// <summary>
/// Handle button timer event: if the button is pressed, change the LED blink rate.
/// </summary>
static void ButtonTimerEventHandler()
if (ConsumeTimerFdEvent(gpioButtonTimerFd) != 0) {
return;
// Check for a button press
GPIO_Value_Type newButtonState;
int result = GPIO_GetValue(gpioButtonFd, &newButtonState);
if (result != 0) {
Log_Debug("ERROR: Could not read button GPIO: %s (%d).\n", strerror(errno), errno);
return;
// If the button has just been pressed, change the LED blink interval
// The button has GPIO_Value_Low when pressed and GPIO_Value_High when released
if (newButtonState != buttonState) {
if (newButtonState == GPIO_Value_Low) {
blinkIntervalIndex = (blinkIntervalIndex + 1) % numBlinkIntervals;
if (SetTimerFdInterval(gpioLedTimerFd, &blinkIntervals[blinkIntervalIndex]) != 0) {
buttonState = newButtonState;
/// <summary>
/// Set up SIGTERM termination handler, initialize peripherals, and set up event handlers.
/// </summary>
/// <returns>0 on success, or -1 on failure</returns>
static int InitPeripheralsAndHandlers(void)
struct sigaction action;
memset(&action, 0, sizeof(struct sigaction));
action.sa_handler = TerminationHandler;
sigaction(SIGTERM, &action, NULL);
epollFd = CreateEpollFd();
if (epollFd < 0) {
return -1;
// Open button GPIO as input, and set up a timer to poll it
Log_Debug("Opening MT3620_RDB_BUTTON_A as input\n");
gpioButtonFd = GPIO_OpenAsInput(MT3620_RDB_BUTTON_A);
if (gpioButtonFd < 0) {
Log_Debug("ERROR: Could not open button GPIO: %s (%d).\n", strerror(errno), errno);
return -1;
struct timespec buttonPressCheckPeriod = {0, 1000000};
gpioButtonTimerFd = CreateTimerFdAndAddToEpoll(epollFd, &buttonPressCheckPeriod,
&ButtonTimerEventHandler, EPOLLIN);
if (gpioButtonTimerFd < 0) {
return -1;
// Open LED GPIO, set as output with value GPIO_Value_High (off), and set up a timer to poll it
Log_Debug("Opening MT3620_RDB_LED1_RED\n");
gpioLedFd = GPIO_OpenAsOutput(MT3620_RDB_LED1_RED, GPIO_OutputMode_PushPull, GPIO_Value_High);
if (gpioLedFd < 0) {
Log_Debug("ERROR: Could not open LED GPIO: %s (%d).\n", strerror(errno), errno);
return -1;
gpioLedTimerFd = CreateTimerFdAndAddToEpoll(epollFd, &blinkIntervals[blinkIntervalIndex],
&LedTimerEventHandler, EPOLLIN);
if (gpioLedTimerFd < 0) {
return -1;
return 0;
/// <summary>
/// Close peripherals and handlers.
/// </summary>
static void ClosePeripheralsAndHandlers(void)
// Leave the LED off
if (gpioLedFd >= 0) {
GPIO_SetValue(gpioLedFd, GPIO_Value_High);
Log_Debug("Closing file descriptors\n");
CloseFdAndPrintError(gpioLedTimerFd, "LedTimer");
CloseFdAndPrintError(gpioLedFd, "GpioLed");
CloseFdAndPrintError(gpioButtonTimerFd, "ButtonTimer");
CloseFdAndPrintError(gpioButtonFd, "GpioButton");
CloseFdAndPrintError(epollFd, "Epoll");
/// <summary>
/// Main entry point for this application.
/// </summary>
int main(int argc, char *argv[])
Log_Debug("Blink application starting\n");
if (InitPeripheralsAndHandlers() != 0) {
// Use epoll to wait for events and trigger handlers, until an error or SIGTERM happens
while (!terminationRequired) {
if (WaitForEventAndCallHandler(epollFd) != 0) {
ClosePeripheralsAndHandlers();
Log_Debug("Application exiting\n");
return 0;
