I have code showing up on screen and checking the temp every 5 seconds. I have an alert setup when it reaches 85+ or below 60. The eblock is working, all plugged in and installed. The temp goes crazy! 71 F to 68F… to 74f and can be stable for a few readings. Sometimes it jumps to 125F. This will be bad for monitoring… Any clues as to why? Using the code provided.
