Hi gents,
We have “Cerbuino Bee” but we didn’t find any tutorial or example code to use SPI
http://www.ghielectronics.com/support/dotnet-micro-framework
As simple as that, Our target is to read from an IMU which talks via SPI
Thnx ![]()
Hi gents,
Thnx ![]()
Have a look at codeshare. There are many examples
@ PetaByte - Start with the official tutorial from GHI
@ RobvanSchelven yea, a lot of examples but not that much for Cerbuino Bee
@ Architect I found those examples for console examples, but I thought this code will conflict with the previous code which was written in Gadgeteer!!
Does it differ from Gadgteer, and will it work in ProgrameStarted(){…}?
Thnx all
@ PetaByte - It’s just something like this:
private static GTI.SPI _spi;
private static GTI.SPI.Configuration _config;
private void ProgramStarted()
_socket = GT.Socket.GetSocket(1, true, null, null);
_config = new GTI.SPI.Configuration(false, 0, 0, false, true, 2000);
_spi = new GTI.SPI(_socket, _config, GTI.SPI.Sharing.Exclusive, _socket, GT.Socket.Pin.Five, null);
@ Justin thnx dude for your continuous support, I will try it soon
@ PetaByte - Your welcome, just make sure you post some pics of finished goodness
@ Justin Thnx
It seems there are some errs because of the name space !!
BTW: Here is all my code which was logging from the GPS to the SD card successfully…
// This code is grapping RAW NMEA data from GPS module,
// and store it into SD card...
// Last modification 1/1/2013, Tue, 8:18PM
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using System.IO;
using Microsoft.SPOT.IO;
namespace GadgeteerApp2
public partial class Program
private GT.Timer _timer;
private string _root;
GHI.OSHW.Hardware.StorageDev.MountSD();
if (VolumeInfo.GetVolumes()[0].IsFormatted)
_root = VolumeInfo.GetVolumes()[0].RootDirectory;
_timer = new GT.Timer(5000);
_timer.Tick += new GT.Timer.TickEventHandler(TimerTick);
_timer.Start();
// Serial Reading
usbSerial.Configure(9600,
GT.Interfaces.Serial.SerialParity.None,
GT.Interfaces.Serial.SerialStopBits.One,
8);
usbSerial.SerialLine.Open();
usbSerial.SerialLine.DataReceived += new
GT.Interfaces.Serial.DataReceivedEventHandler(SerialLine_DataReceived);
void TimerTick(GT.Timer timer)
string fileName = Path.Combine(_root, "DONETracksLogNMEA11111.txt");
Stream stream;
// GPS Reading
int NumberOfBytesToRead = usbSerial.SerialLine.BytesToRead;
byte[] readInputBuffer = new byte[NumberOfBytesToRead];
usbSerial.SerialLine.Read(readInputBuffer, 0, NumberOfBytesToRead);
if(File.Exists(fileName))
stream = File.OpenWrite(fileName);
stream.Position = stream.Length; //FM Not To Overwrite
stream = File.Create(fileName);
using(var writer = new StreamWriter(stream))
// GPS writing to SD
for (int j = 0; j < NumberOfBytesToRead; j++)
char a = (char)readInputBuffer[j];
writer.Write(a.ToString());
writer.WriteLine("***");
stream.Dispose();
void SerialLine_DataReceived(GT.Interfaces.Serial sender, System.IO.Ports.SerialData data)
GTI is an abbreviation for Gadgeteer.Interfaces, so you’ll want a declaration near the top saying:
using GTI = Gadgeteer.Interfaces;
There’s also an error because _socket isn’t declared, maybe add to the other variable declarations in Program:
private static GT.Socket _socket;
RorschachUK
How did you create your project? And what does your designer surface look like, what mainboard and modules?
Your namespace reference issue is because of a missing reference but the normal Gadgeteer project setup should create everything you need (not that I can test it, I’m using my Surface right now). You could add it manually, you’re looking for Gadgeteer interfaces. Edit: yes, its the using statement its missing… but that usually comes in a default project too
Hi all,
@ RorschachUK:
You are right, we added these definitions and (Gadgeteer.SPI) reference, and everything was pretty good and no errs.
NOW WE ARE TRYING TO READ FROM THE SENSOR
Any Idea???
Thnx all
Or even if you tell us how to how loop-back test
To do a loop back test you must connect SDO and SDI together.
byte[] BytesWrite=new byte[]{0,1,2,3,4};
byte[] BytesRead=new byte[5];
_spi.WriteRead(BytesWrite, BytesRead);
After the WriteRead the BytesRead should contain the same bytes as BytesWrite…
SPI1 is documented as on the following:
13 PB3 SPI1 SCK
12 PB4 SPI1 MISO, PWM 7
11 PB5 SPI1 MOSI, PWM 6
and also on Gadgeteer socket 1:
Pin 7 SPI1 MOSI PWM 6, CAN2 RX, PB5
Pin 8 SPI1 MISO PWM 7, PB4
Pin 9 SPI1 SCK PWM 8, PB3
So lets step through the foundation concepts here.
Is allocating Socket 1
Is setting up the SPI general configuration
Is using the socket and configuration you just created, in exclusive mode, and is using socket pin 5 as the Chip Select pin.
One thing that really helps you understand this kind of thing is to start re-typing the lines of code in your program rather than just pasting it in from somewhere else - you’ll see that intellisense pops up great information about what the command structure is, what the parameters mean, and what other options you might find if you need it.
Guys, I don’t know how to thank you :))
It was working perfectly!
I used GT.Timer this time, and it was working perfectly, but suddenly I got this output:
[em]The thread ‘’ (0x3) has exited with code 0 (0x0).
[/em]
Unfortunately, somehow after a while the result started to be missed up again!!
Here is my code:
namespace GadgeteerApp3
GT.Timer timer = new GT.Timer(1000);
public void ProgramStarted()
timer.Tick += new GT.Timer.TickEventHandler(spiTimer);
timer.Start();
//Timer MyTimer = new Timer(new TimerCallback(spiTimer), null, 5000, 1000);
//Thread.Sleep(Timeout.Infinite);
static void spiTimer(GT.Timer timer) {
byte[] BytesWrite = new byte[] { 0, 1, 2, 3, 4 };
byte[] BytesRead = new byte[5];
Debug.Print("**********");
for (int i = 0; i < 5; i++)
Debug.Print(BytesRead[i].ToString());
