@ Justin - Nope, not falling for it. Nice try bub.
@ Justin - I’m falling for it, hyperventilating
Going out to my mailbox now…
@ terrence - oooo look…its Friday down under
@ Justin - That is my kind of antenna. Now show a little more on that board.
edit: or at least the long one laying down. The other one looks pretty exotic. Some sort of interstellar antenna device?
walking back down to the mailbox…
hope you’re not at the mailbox waiting
@ Brett - What? I can’t hear you down here next to the road. [tapping foot]
@ Justin - Oh ya. Getting closer. When will you start gluing chips down?
@ terrence - you mean these bad boys?
@ terrence - it works
@ Justin - That’s exactly what I mean. Finally got some in stock.
@ Justin - Can you post some code so I can start looking at it?
@ Justin - Whoaaa… this is what I looking for, droollll…
Do you make Lora module for gadgeteer ?
another alternative I can buy LR Click | Mikroe and quail board…
@ mifmasterz -
Forgive my ignorance of LoRa as I ask this question.
Can these devices support peer-to-peer or star networks? Or, does it require a higher level gateway to tie them all together?
@ skeller - Full LoRa requires a gateway but the devices also support p2p which is how i am using them at the moment.
@ Justin - from the looks of it, I can’t see another chip on the LoRa board. The mDot has an Arm M4, and soon will have an M0 cortex for business logic. Does your board have a chip on it or will we have to use it in conjunction with another ghi chip?
Also, what about a battery hookup?
I need remote solutions for :
temp, humidity, pressure, battery, logic => LoRa to Azure.
PIR, battery, logic => LoRa to Azure.
@ Terrence - You are indeed correct, this board is Gadgeteer so needs to be plugged into a Gadgeteer mainboard.
But fear not my young Padawan for the other LoRa board i have will turn you into a giggling school girl
@ Justin - [quote]
But fear not my young Padawan for the other LoRa board i have will turn you into a giggling school girl [/quote]
Bring it on. Now if we can just get MicroChip to deliver 915s.
