I had some spare time (Ya… like I always have at my age)
I was having a bit of a problem with I2C and I found some old code by GHI and it got me brain working again.
Posting for anybody that needs something to get them started.
Nothing pretty but it worked!
Based on GHI Electronics Source Code
ghi_elect-gadgeteer-5c8596ffc9f6.zip
TempHumidSI70_43.cs (namespace Gadgeteer.Modules.GHIElectronics)
Using a USB FTDI 3.3V cable for serial. (PC using Tera Term)
Pin
1 Black Ground To 8 pin header GND(Arrow Mark on connector)
2 Brown CTS# (Not used)
3 Red VCC(+5V) (Not used)
4 Orange TXD To 8 pin header COM1 RX <--- 8 pin header D0 COM1
5 Yellow RXD To 8 pin header COM1 TX <--- 8 pin header D1 COM1
6 Green RTS# (Not used)
Using a Panda III
Using a TempHumid SI70 Gadgeteer Module and Breakout Module
Breakout pin Gnd to Panda III Gnd
Breakout pin 3V3 to Panda III 3V3
Breakout pin P4 to Panda III 8 Pin Header D3 (I2C_SCL)
Breakout pin P5 to Panda III 8 Pin Header D2 (I2C_SDA)
PB7/I2C1/SDA Cpu Pin 93 - X2 8 pin header Pin 3 - D2
PB6/I2C1/SCL Cpu Pin 92 - X2 8 pin header Pin 4 - D3
using GHIElectronics.TinyCLR.Devices.I2c;
using GHIElectronics.TinyCLR.Devices.Enumeration;
using GTC_DS = GHIElectronics.TinyCLR.Devices.SerialCommunication;
using GTC_SS = GHIElectronics.TinyCLR.Storage.Streams;
namespace TinyCLR_I2C_Test
private static bool loop = true;
// On board LED
public static GpioPin LED4; //Red PE9/PWM0
// I2C1
private static I2cDevice I2c;
public static GpioPin SCL;
public static GpioPin SDA;
// Serial
private static GTC_DS.SerialDevice _com1;
private static GTC_SS.IOutputStream _outStream;
private static GTC_SS.IInputStream _inStream;
private static char[] charsToTrim = { '-', '0' };
private static GTC_SS.Buffer _Serialmsgbuffer;
private static GTC_SS.Buffer _Serialreadbuffer;
// * Slave address *
private static byte I2C_ADDRESS = 0x40; // Dec. 64 Bin. 01000000
// * Measure Relative Humidity, Clock stretching (Hold Master Mode) *
private static byte MEASURE_HUMIDITY_HOLD = 0xE5; // Dec. 229 Bin. 1110 0101
// * Read Temperature Value from Previous RH Measurement *
private static byte READ_TEMP_FROM_PREVIOUS = 0xE0; // Dec. 224 Bin. 1110 0000
// Measure Relative Humidity, No Hold Master Mode
//private static byte RH_NOHOLD = 0xF5; // Dec. 245 Bin. 1111 0101
// Measure Temperature, Clock stretching (Hold Master Mode)
//private static byte TEMP_HOLD = 0xE3; // Dec. 227 Bin. 1110 0011
// Measure Temperature, No Hold Master Mode
//private static byte TEMP_NOHOLD = 0xF3; // Dec. 243 Bin. 1111 0011
// Reset
//private static byte RESET = 0xFE; // Dec. 254 Bin. 1111 1110
// Write RH/T User Register 1
//private static byte WRITE_USER_REG = 0xE6; // Dec. 230 Bin. 1110 0110
// Read RH/T User Register 1
//private static byte READ_USER_REG = 0xE7; // Dec. 231 Bin. 1110 0111
// Write Heater Control Register 0x51 // Dec. 81 Bin. 0101 0001
// Read Heater Control Register 0x11 // Dec. 17 Bin. 0001 0001
private static byte[] I2CwriteBuffer1;
private static byte[] I2CwriteBuffer2;
private static byte[] I2CreadBuffer1;
private static byte[] I2CreadBuffer2;
private static bool blink = false;
var gpio = GpioController.GetDefault();
// PC Board Red LED PE9/PWM0 CPU Pin 40
LED4 = gpio.OpenPin(FEZPandaIII.Gpio.Led4);
LED4.SetDriveMode(GpioPinDriveMode.Output);
// COM port using a USB FTDI 3.3V cable for serial. (PC using Tera Term)
_com1 = GTC_DS.SerialDevice.FromId("COM1");
_outStream = _com1.OutputStream;
_inStream = _com1.InputStream;
// Returns one I2C device and 4 SPI devices
// Devices Returns [0] = "I2C1", [1] = "SPI1", [2] = "SPI2", [3] = "SPI3", [4] = "SPI4"
var Devices = DeviceInformation.FindAll(FEZPandaIII.I2cBus.I2c1);
// Device I2C1 Slave address
I2cConnectionSettings Setting = new I2cConnectionSettings(I2C_ADDRESS);
//Setting.BusSpeed = I2cBusSpeed.StandardMode; // 100kHz
// Or
Setting.BusSpeed = I2cBusSpeed.FastMode; // 400kHz
I2c = I2cDevice.FromId(Devices[0].Id, Setting);
SendMsg("\r\n Type a upper case Q to exit the while loop\r\n");
SendMsg("\r\n Type a lower case t to read Temperature and RelativeHumidity\r\n");
SendMsg("\r\n i2c.DeviceId Dec: " + I2c.ConnectionSettings.SlaveAddress.ToString() +
" Hex: " + I2c.ConnectionSettings.SlaveAddress.ToString("X"));
SendMsg("\r\n i2c.BusSpeed " + I2c.ConnectionSettings.BusSpeed.ToString());
SendMsg("\r\n StandardMode = 0 - FastMode = 1\r\n");
// Here we go
while (loop)
ToggleLED();
_Serialreadbuffer = new GTC_SS.Buffer(2);
if (_inStream.Read(_Serialreadbuffer, _Serialreadbuffer.Capacity, GTC_SS.InputStreamOptions.None) > 0)
byte[] b = _Serialreadbuffer.Data;
string stng = b.GetValue(0).ToString();
// Q ascii - 81 Dec , 51 Hex
// q ascii - 113 Dec , 71 Hex
if (stng == "81") // Is character received a uppercase Q?
SendMsg("\r\n !!! Upper case Q received. Exit while loop.");
SendMsg("\r\nReset the board.\r\n");
loop = false;
if (stng == "114") //Char r - 114 Dec , 0X72 Hex
//Read (Not used)
SendMsg("\r\n The r key was pressed\r\n");
if (stng == "119") //Char w - 119 Dec , 0x77 Hex
//Write (Not used)
SendMsg("\r\n The w key was pressed (write)\r\n");
if (stng == "116") //Char t - 119 Dec , 0x74 Hex
SendMsg("\r\n The t key was pressed - I2C test\r\n");
TempHumidity();
Thread.Sleep(500);
// while
SendMsg("\r\nExit while()\r\n");
// Main
private static void TempHumidity()
I2CwriteBuffer1 = new byte[1] { MEASURE_HUMIDITY_HOLD }; //0xE5
I2CwriteBuffer2 = new byte[1] { READ_TEMP_FROM_PREVIOUS }; //0xE0
I2CreadBuffer1 = new byte[2];
I2CreadBuffer2 = new byte[2];
I2c.WriteRead(I2CwriteBuffer1, I2CreadBuffer1);
Thread.Sleep(10);
I2c.WriteRead(I2CwriteBuffer2, I2CreadBuffer2);
int rawRH = I2CreadBuffer1[0] << 8 | I2CreadBuffer1[1];
int rawTemp = I2CreadBuffer2[0] << 8 | I2CreadBuffer2[1];
SendMsg("\r\n rawRH " + rawRH.ToString());
SendMsg("\r\n rawTemp " + rawTemp.ToString() + "\r\n");
double temperature = 175.72 * rawTemp / 65536.0 - 46.85;
double relativeHumidity = 125.0 * rawRH / 65536.0 - 6.0;
if (relativeHumidity < 0.0)
relativeHumidity = 0.0;
if (relativeHumidity > 100.0)
relativeHumidity = 100.0;
SendMsg("\r\n Celsius: " + temperature.ToString("F1"));
SendMsg("\r\n Fahrenheit: " + (temperature * 1.8 + 32.0).ToString("F1"));
SendMsg("\r\n RH: " + relativeHumidity.ToString("F1") + "\r\n");
// PC Board Red LED
private static void ToggleLED()
if (blink)
LED4.Write(GpioPinValue.High);
LED4.Write(GpioPinValue.Low);
blink = !blink;
private static void SendMsg(string theMsg)
// Send theMsg to the serial terminal.
_Serialmsgbuffer = new GTC_SS.Buffer(System.Text.Encoding.UTF8.GetBytes(theMsg));
_outStream.Write(_Serialmsgbuffer);
private static byte[] GetBytes(string theMsg)
return System.Text.Encoding.UTF8.GetBytes(theMsg);
} // Class
} // Namespace
Thanks GHI for the code!
